[GRASS5] r.lzw2z updated...
I've update the r.lzw2z conversion module.
1. Hopefully fix a NULL file problem Markus reported, now never uses the
   G_open_cell* functions (which I think was where the problem was??).
2. Build in intelligence about FP rasters that have already been
converted. Both script and libraries now set lzw_compression_bits in
cell_misc/<name>/f_format to '-1'. This value makes no sense for LZW
and is unused by libz.
wget http://www.jps.net/egm2/r.lzw2z/r.lzw2z.tar.gz
Eric G. Miller <egm2@jps.net>
subject 'unsubscribe grass5'
Eric,
just tested the updated module:
- no segfault any more, but
- I get this warning:
   Processing aspect@helge ... Copying ... WARNING:
   cell_misc/aspect/f_format file may be corrupted!
   Processing slope@helge ... Copying ... WARNING: cell_misc/slope/f_format
There seems to be one bug left.
On Mon, Jan 22, 2001 at 09:36:25AM +0000, Markus Neteler wrote:
Eric,
Could you check what one of these files looks like? Maybe I need to
handle a return value differently... Following conversion it should
look like...
type: float
byte_order: xdr
lzw_compression_bits: -1
Prior to conversion, lzw_compression_bits should be between 9 and 20.
If it failed to update/write the file, the warning is correct. However,
we don't want it to fail :wink:
> Eric,
look like...
type: float
byte_order: xdr
Mhhh, it is as above!
type: double
byte_order: xdr
Yes, but what could be wrong?
Maybe it is o.k., just the warning is wrong.
Note: I didn't test the map (should have done). As I just
trashed my GRASs for recompilation, I cannot test this minute.
Update mail should follow in 10 minutes...
Hi Eric,
Eric,
I have tried the converted maps: They are OK! So maybe just
the return value is reverted (it simply shouldn't print above warning).
Can't see any problems except the confusing warning with your updated
r.lzw2z
Re-running it is o.k. as well:
Skipping raster aspect@demomapset -- Not LZW compressed
Skipping raster slope@demomapset -- Not LZW compressed
So, if you revert the if-clause (or whatever) for the WARNING,
I think r.lzw2z is working well.
Continuing to convert 1000s of maps... :slight_smile:
On Mon, Jan 22, 2001 at 06:01:03PM +0000, Markus Neteler wrote:
> Eric,
r.lzw2z
Okay, r.lzw2z is slightly updated. Should fix the small error when only
one raster exists in fcell/ (wasn't dangerous). Tried to fix warning
message above. Can't really figure it out. If I add a print statement,
to print the "stat" value returned by the G_fwrite_key_value() function,
the error goes away. Go figure...
All I can reason is that the calling function G_write_key_value_file()
checks the return value of fclose() against EOF and reports an error
code if EOF was returned. Maybe a glibc bug? I haven't really tested
that possibility. Anyway, it always seems to work correctly whether or
not the return code is correct. I did check the G_fwrite_key_value() is
returning zero. Hmm...
Eric,
just tried your updated version.
A sample session is looking like this:
Doing translations ...
Processing dgm12_5@hude ... Copying ... Done!
Processing asp@hude ... Copying ... Done!
Processing dgm5_rst@hude ... Copying ... Done!
WARNING: No lzw_compression_bits value in
         /home/neteler/grassdata5/hude/hude/cell_misc/slope_rst/f_format
Skipping raster slope_rst@hude -- Not LZW compressed
Processing aspect_rst@hude ... Copying ... Done!
Processing pcurv@hude ... Copying ... Done!
         /home/neteler/grassdata5/hude/hude/cell_misc/tcurv/f_format
Skipping raster tcurv@hude -- Not LZW compressed
         /home/neteler/grassdata5/hude/hude/cell_misc/mcurv/f_format
Skipping raster mcurv@hude -- Not LZW compressed
         /home/neteler/grassdata5/hude/hude/cell_misc/pcurv_rst/f_format
Skipping raster pcurv_rst@hude -- Not LZW compressed
The files with WARNING now have a f_format entry like this:
more f_format
type: float
byte_order: xdr
lzw_compression_bits: 0
What does this indicate? Was it an uncompressed file (the map was generated
with s.surf.rst) ?
The map is corrupted now:
d.rast tcurv
WARNING: error reading compressed map [tcurv] in mapset [hude], row 91
Maybe that's the last bug...
On Tue, Jan 23, 2001 at 09:42:47AM +0000, Markus Neteler wrote:
[snip]
more f_format
type: float
byte_order: xdr
with s.surf.rst) ?
d.rast tcurv
Try changing the lzw_compression_bits to something like "9" and
re-running the r.lzw2z script. Note: r.lzw2z wouldn't have touch the
f_format file (except to read) if it said it skipped the file. The
problem seems to be that somehow s.surf.rst writes an lzw compressed
file but lzw_compression_bits is not set correctly (should be between 9
and 20). Not sure how that would happen. The reason to have these
tests of lzw_compression_bits is so the program doesn't even try to read
non-LZW compressed rasters (which would always fail and cause the
program to exit). But, then it has to rely on lzw_compression_bits
being set to a valid value in order to make the determination (it seems
to be the only indicator of LZW compression). The maps are probably not
corrupted, just LZW compressed with a bogus lzw_compression_bits number.
[snip]
> more f_format
> type: float
> byte_order: xdr
> with s.surf.rst) ?
> d.rast tcurv
A good idea! I have changed the f_format and re-run the converter.
r.lzw2z then runs well:
r.lzw2z slope_rst
Processing slope_rst@hude ... Copying ... Done!
and I can even display the map.
The problem with s.surf.rst is that it doesn't use the GRASS functions
to write maps (huh!). Therefore the lzw_compression_bits: 0 occurs.
The module uses "fwrite" as far as I understand
src/sites/s.surf.rst/main.c
Maybe I am wrong and src/libes/rst_gmsl/interp_float/output2d.c is
used with G_put_f_raster_row().
Ah yes, see
./interp_float/resout2dmod.c
./interp_float/resout2d.c
    cf1 = G_open_fp_cell_new_uncompressed (params->elev);
Maybe that's the reason?
Could you change the r.lzw2z accordingly so that it can handle these
data as well without WARNING?
Ah yes, see
I will update to compare against the -1 token instead of checking the
9-20 range. This ought to solve the problem for most cases...
