Dear GRASS users,
I wrote this little script to perform a task similar to r.average and r.median.
this command takes three arguments: base cover output and writes a raster map "output" containing the maximum values found on the "cover" map for every different "base" value.
Copy this script to a file called r.maximum (or whatever you like) and
chmod a+x r.maximum
Invocation is
r.maximum base cover output
Hope you find this useful.
Raffaele Douglas Candidi Tommasi Crudeli
__________________
#!/bin/bash
if [ -z "$1" ] || [ -z "$2" ] || [ -z $3 ]; then
echo
echo Usage: $0 base cover output
echo
exit
fi
if [ ! -f $LOCATION"/cell/$1" ]; then
echo
echo "Filename $1 not found"
echo
exit
fi
if [ ! -f $LOCATION"/cell/$2" ]; then
echo
echo "Filename $2 not found"
echo
exit
fi
r.stats -1Cn input=$1,$2|sort -n|awk '
BEGIN {
min=10000000
max=-10000000
cat=1
if ($1==cat) {
if ($2 < min) {
min=$2
if ($2 >max) {
max=$2
}else{
printf ("%s %f %f\n",cat,min,max)
#printf ("%s:%s:%f\n",cat,cat,min)
#printf ("%s=%f\n",cat,min)
cat=$1
min=10000000
max=-10000000
END {
'|r.recode -a input=$1 output=$3
