[GRASS5] r.patch color problem
Hi, Markus, hi, all,
the guilty one (at least with my compiler) is
int G_is_zero_value in do_patch.c
i made it read like
int G_is_zero_value(
    void *rast,
    RASTER_MAP_TYPE data_type)
/* insert 0 check here */
  return G_is_null_value(rast, data_type) ||
(G_get_raster_value_d(rast, data_type) != 0.0 ? 0 :
1);
it worked ok in patching with zeroflag set to 1, when
there were zeros on the
ovelayed map. though, it seems to me if you want to
overlay on something that is
not zero (for real transparensy), this check should be
removed.
however i can't just checkout to cvs:
------------------------------------CUT HERE
root@spruce /root]# ssh -v -p 2402 intevation.de -l
alex cvs --help
SSH Version 1.2.27 [i686-unknown-linux], protocol
version 1.5.
Compiled with RSAREF.
spruce.sixote.ru: Reading configuration data
/etc/ssh/ssh_config
spruce.sixote.ru: ssh_connect: getuid 0 geteuid 0 anon
0
spruce.sixote.ru: Connecting to intevation.de
[131.173.30.110] port 2402.
spruce.sixote.ru: Allocated local port 1023.
spruce.sixote.ru: Connection established.
spruce.sixote.ru: Remote protocol version 1.5, remote
software version 1.2.27
spruce.sixote.ru: Waiting for server public key.
spruce.sixote.ru: Received server public key (768
bits) and host key (1024 bits).
spruce.sixote.ru: Host 'intevation.de' is known and
matches the host key.
spruce.sixote.ru: Initializing random; seed file
/root/.ssh/random_seed
spruce.sixote.ru: Encryption type: idea
spruce.sixote.ru: Sent encrypted session key.
spruce.sixote.ru: Installing crc compensation attack
detector.
spruce.sixote.ru: Received encrypted confirmation.
spruce.sixote.ru: Remote: Server does not permit empty
password login.
spruce.sixote.ru: Trying rhosts or /etc/hosts.equiv
with RSA host authentication.
spruce.sixote.ru: Server refused our rhosts
authentication or host key.
spruce.sixote.ru: Connection to authentication agent
opened.
spruce.sixote.ru: Trying RSA authentication via agent
with 'root@spruce.sixote.ru'
spruce.sixote.ru: Server refused our key.
spruce.sixote.ru: RSA authentication using agent
refused.
spruce.sixote.ru: Trying RSA authentication with key
spruce.sixote.ru: Doing password authentication.
alex@intevation.de's password:
Permission denied.
[root@spruce /root]#
since last time i used cvs, i may have changed the
computer.
i still remember the passphrase, and it recognizes it
after ssh-add.
what shall i do now, Bernhard?
best regards,
alex
--- Markus Neteler <neteler@geog.uni-hannover.de>
wrote:
after upgrading r.patch to support additionally 0
(instead
of NULL) for transparency (-z flag), I still face a
color
problem.
I have a set of single color input maps: rasterized
layers
of a toposheet:
- one layer road lines (black)
- one layer forest areas (green)
- one layer lakes
etc.
These layers I want to patch to receive the full
toposheet
back. But the resulting file is black and white
only.
The original colors are not preserved. All input
maps are
int (CELL type).
When looking into the sources:
src/raster/r.patch/cmd/support.c
there is a check:
[line 49]
  do_colr = *colr_ok && (G_read_colors (names[i],
mapset, &pcolr) >= 0);
As I have colored maps, it should be true. But it is
set to
false. Maybe there is a bug in G_read_colors?
I would be glad to receive some assistance here.
From GRASS 4 I remember that you receive strange
color results of
mosaicking several colored aerial photos. Probably
fixing above
problem would fix this, too.
Thanks for listening
If you want to unsubscribe from GRASS Development
Team mailing list write to:
subject 'unsubscribe grass5'
__________________________________________________
Do You Yahoo!?
Yahoo! Mail - Free email you can access from anywhere!
http://mail.yahoo.com/
i made it read like
    void *rast,
1);
removed.
[... Bernhard will help to fix it...]
Huidae Cho has applied your patch. But...
I have tested with two raster line maps now.
One map with a blue line, one with a brown line,
rest zero (0).
Using r.patch -z in=map1,map2 out=patch
I would expect a map with two colored line (one blue,
one brown). But still the color is taken from the first
map only. The patch is o.k. (means that G_is_zero_value
does it's job) but I guess there is a problem in
support.c.
Could you take another look into it?
Many thanks
