Markus,
It looks like profile coordinates provided on the command are NOT being parsed with G_scan_... . They are being parsed with sscanf which will not work with the sexagesimal format.
If you replace the following lines in main.c (r.profile)
sscanf(parm.profile->answers[i], "%lf", &e1);
sscanf(parm.profile->answers[i + 1], "%lf", &n1);
sscanf(parm.profile->answers[i + 2], "%lf", &e2);
sscanf(parm.profile->answers[i + 3], "%lf", &n2);
with
G_scan_easting(parm.profile->answers[i], &e1, G_projection());
G_scan_northing(parm.profile->answers[i+1], &n1, G_projection());
G_scan_easting(parm.profile->answers[i+2], &e2, G_projection()); G_scan_northing(parm.profile->answers[i+3], &n2, G_projection());
that should take care of the problem.
Bob
Markus Neteler wrote:
I tried to use the current r.profile do compare SRTM V1 and
the new SRTM V2 in a LatLong location. Unfortunately coordinate
input in sexagesimal format didn't produce any output while
decimal degree input does:
r.profile N46E011_V1 profile=11:09:19.694051E,46:10:38.328612N,11:09:19.694051E,46:02:38.328612N
-> nothing, but also no error
r.profile N46E011_V1 profile=11.15524237,46.17754171,11.15524237,46.04062008
-> results
Any ideas? G_scan_easting() and G_scan_northing() seem to be used.
grass5 mailing list
grass5@grass.itc.it
http://grass.itc.it/mailman/listinfo/grass5
