I just noticed that when I ported r.support, I may have not written the
makefiles properly.
I just realized that commands in etc/support/ are also copied to etc/ as
well. (modcats, modcolr, modhead, modhist)
Could someone review the makefiles in raster/r.support/... and let me
know how to correct this minor problem? I fail to see the problem.
Thanks!
Brad Douglas <rez@touchofmadness.com>
makefiles properly.
Inspired by db/base/Makefile I suggest the attached example.
(attachments)
Makefile (390 Bytes)
makefiles properly.
I suggest replacing:
$(INSTALL) -m 755 $(ETC)/$(PGM) $(ETC)/support
with:
mv $(ETC)/$(PGM) $(ETC)/support/
I wouldn't recommend adding an explicit linking command (i.e.
a copy of the rules for the "etc" target). If the linking command
changes, we want to be able to just change Module.make, and not have
to search all of the Makefiles for private copies.
Actually, is there any reason the programs need their own subdirectory
and can't just go directly into $(ETC)?
with:
No particular reason it couldn't go in $(ETC). I put it in
$(ETC)/support to keep $(ETC) uncluttered and easy to identify programs
associated with r.support.
Of course, I could just rewrite r.support to not use these all together
and just have one binary called r.support. That is probably the optimal
solution.
Let me know if you would prefer them go in $(ETC) or if I should
reorganize r.support as a single binary.
> with:
solution.
Actually, I'd rather go the other way, i.e. have separate user-visible
programs (i.e. r.support.*) for each category rather than forcing the
use of the r.support menu.
Supporting non-interactive use would be an added bonus (I've already
written r.region).
Rename them to r.support.* and put them in $(BIN).
