[GRASS5] r.terraflow problems
Hello
I tried compiling r.terraflow with the SGI C++ compiler on IRIX and got a
big load of errors, make output appended below. Just for information.
Perhaps its not worth trying to fix them all until in general it is tidied
up more though. I am not into C++ so can't really help.
Paul
(needed to remove -Wall from Gmakefile first)
  SRC = /indigo-disk2/grass/grass/src
  CMD = /indigo-disk2/grass/grass/src/CMD
  UNUSED = /indigo-disk2/grass/grass/unused
  HEADER = head.mips-sgi-irix6.2
  ARCH = mips-sgi-irix6.2
  GISBASE = /indigo-disk2/grass/grass/dist.mips-sgi-irix6.2
  VERSION = 5.0.2-cvs January 2003
/indigo-disk2/grass/grass/src.contrib/DUKE/r.terraflow
  make -f OBJ.mips-sgi-irix6.2/make.rules
mkdir OBJ.mips-sgi-irix6.2/FLOAT ; true
mkdir: cannot create directory `OBJ.mips-sgi-irix6.2/FLOAT': File exists
mkdir OBJ.mips-sgi-irix6.2/SHORT ; true
mkdir: cannot create directory `OBJ.mips-sgi-irix6.2/SHORT': File exists
CC -c -I/indigo-disk2/grass/grass/src/include -I/indigo-disk2/grass/doom.ee.qub.ac.uk/include -g -I/indigo-disk2/grass/doom.ee.qub.ac.uk/include -I./IOStream/include -DUSER=\"paulk\" -DNODATA_FIX -D_FILE_OFFSET_BITS=64 -DELEV_FLOAT main.cc -o OBJ.mips-sgi-irix6.2/FLOAT/main.o
"./IOStream/include/mm.h", line 136: error(3181): array of functions is not
          allowed
    friend void operator delete(void *);
"./IOStream/include/mm.h", line 136: error(3596): an operator name must be
          declared as a function
"./IOStream/include/mm.h", line 136: error(3358): invalid friend declaration
"./IOStream/include/ami_stream.h", line 248: error(3428): default argument is
          not allowed
          AMI_stream_type st = AMI_READ_WRITE_STREAM) {
"./IOStream/include/ami_stream.h", line 409: error(3428): default argument is
          not allowed
             MM_stream_usage usage_type= MM_STREAM_USAGE_OVERHEAD) {
"./IOStream/include/queue.h", line 61: error(3114): identifier "bool" is
          undefined
    bool enqueue(T &);
"./IOStream/include/queue.h", line 62: error(3114): identifier "bool" is
          undefined
    bool dequeue(T *);
"./IOStream/include/queue.h", line 63: error(3114): identifier "bool" is
          undefined
    bool peek(int offset, T *);
"./IOStream/include/queue.h", line 64: error(3114): identifier "bool" is
          undefined
    bool isEmpty() const { return len==0; };
"./IOStream/include/queue.h", line 86: error(3114): identifier "bool" is
          undefined
  bool
"./IOStream/include/queue.h", line 97: error(3114): identifier "bool" is
          undefined
  bool
"./IOStream/include/queue.h", line 110: error(3114): identifier "bool" is
          undefined
  bool
"./IOStream/include/replacementHeap.h", line 156: error(3235): declaration is
          incompatible with "ReplacementHeap<T,
          Compare>::ReplacementHeap(size_t, queue<char *> *)" (declared at
          line 118)
  ReplacementHeap<T,Compare>::ReplacementHeap<T,Compare>(size_t g_arity,
"./IOStream/include/replacementHeap.h", line 156: error(3158): expected a ";"
"./IOStream/include/replacementHeap.h", line 223: warning(3109): parsing
          restarts here after previous syntax error
      cerr.flush();
"./IOStream/include/replacementHeap.h", line 224: error(3254): expected a
          declaration
"./IOStream/include/replacementHeap.h", line 307: warning(3109): parsing
    buildheap();
"./IOStream/include/replacementHeap.h", line 308: error(3254): expected a
          declaration
"./IOStream/include/replacementHeap.h", line 365: warning(3109): parsing
      heapify(min_index);
"./IOStream/include/replacementHeap.h", line 366: error(3254): expected a
          declaration
"./IOStream/include/replacementHeap.h", line 369: error(3254): expected a
          declaration
"./IOStream/include/replacementHeap.h", line 417: warning(3109): parsing
    if (size > 0) heapify(0);
"./IOStream/include/replacementHeap.h", line 419: error(3254): expected a
          declaration
    return min;
"./IOStream/include/replacementHeap.h", line 420: error(3254): expected a
          declaration
"./IOStream/include/replacementHeapBlock.h", line 70: warning(3109): parsing
"./IOStream/include/replacementHeapBlock.h", line 89: error(3170): this
          declaration has no storage class or type specifier
    BlockHeapElement<T>* mergeHeap; //the heap;
"./IOStream/include/replacementHeapBlock.h", line 89: error(3158): expected a
"./IOStream/include/replacementHeapBlock.h", line 162: error(3235):
          declaration is incompatible with "ReplacementHeapBlock<T,
          Compare>::ReplacementHeapBlock(queue<MEM_STREAM<T> *> *)" (declared
          at line 120)
  ::ReplacementHeapBlock<T,Compare>(queue <MEM_STREAM<T>*> *runList) {
"./IOStream/include/replacementHeapBlock.h", line 162: error(3158): expected a
"./IOStream/include/replacementHeapBlock.h", line 225: warning(3109): parsing
      cerr.flush();
"./IOStream/include/replacementHeapBlock.h", line 226: error(3254): expected a
          declaration
"./IOStream/include/replacementHeapBlock.h", line 309: warning(3109): parsing
    buildheap();
"./IOStream/include/replacementHeapBlock.h", line 310: error(3254): expected a
          declaration
"./IOStream/include/replacementHeapBlock.h", line 341: warning(3109): parsing
      heapify(min_index);
"./IOStream/include/replacementHeapBlock.h", line 342: error(3254): expected a
          declaration
"./IOStream/include/replacementHeapBlock.h", line 345: error(3254): expected a
          declaration
"./IOStream/include/replacementHeapBlock.h", line 393: warning(3109): parsing
"./IOStream/include/replacementHeapBlock.h", line 395: error(3254): expected a
          declaration
    return min;
"./IOStream/include/replacementHeapBlock.h", line 396: error(3254): expected a
          declaration
"./IOStream/include/ami_sort_impl.h", line 94: warning(3109): parsing restarts
          << "\n";
"./IOStream/include/ami_sort_impl.h", line 95: error(3254): expected a
          declaration
"./IOStream/include/ami_sort_impl.h", line 147: warning(3109): parsing
      str = new MEM_STREAM<T>( &(data[i*block_size]), crt_block_size);
"./IOStream/include/ami_sort_impl.h", line 148: error(3170): this declaration
      blockList->enqueue(str);
"./IOStream/include/ami_sort_impl.h", line 148: error(3158): expected a ";"
"./IOStream/include/ami_sort_impl.h", line 149: error(3254): expected a
          declaration
"./IOStream/include/ami_sort_impl.h", line 153: error(3114): identifier "T" is
          undefined
    ReplacementHeapBlock<T,Compare> rheap(blockList);
          "Compare" is undefined
          detected during instantiation of class
                    "ReplacementHeapBlock<<error-type>, <error-type>>" at line
                    153 of "./IOStream/include/ami_sort_impl.h"
"./IOStream/include/ami_sort_impl.h", line 153: error(3370): no instance of
          constructor "ReplacementHeapBlock<<error-type>,
          <error-type>>::ReplacementHeapBlock" matches the argument list
"./IOStream/include/ami_sort_impl.h", line 154: error(3254): expected a
          declaration
    SDEBUG rheap.print(cerr);
"./IOStream/include/ami_sort_impl.h", line 156: error(3114): identifier "T" is
          undefined
    T elt;
"./IOStream/include/ami_sort_impl.h", line 157: error(3114): identifier "T" is
          undefined
    T* outdata = new T [run_size];
"./IOStream/include/ami_sort_impl.h", line 157: error(3172): expected a type
          specifier
          "run_size" is undefined
"./IOStream/include/ami_sort_impl.h", line 158: error(3254): expected a
          declaration
    while (!rheap.empty()) {
"./IOStream/include/ami_sort_impl.h", line 164: warning(3109): parsing
    assert( i == run_size && blockList->length() == 0);
"./IOStream/include/ami_sort_impl.h", line 165: error(3254): expected a
          declaration
    delete blockList;
"./IOStream/include/ami_sort_impl.h", line 167: error(3114): identifier "T" is
          undefined
    T* tmp = data;
"./IOStream/include/ami_sort_impl.h", line 167: error(3114): identifier "data"
          is undefined
    T* tmp = data;
"./IOStream/include/ami_sort_impl.h", line 168: error(3254): expected a
          declaration
    delete tmp;
"./IOStream/include/ami_sort_impl.h", line 169: error(3170): this declaration
    data = outdata;
"./IOStream/include/ami_sort_impl.h", line 169: error(3232): a value of type
          "<error-type> *" cannot be used to initialize an entity of type "int"
    data = outdata;
"./IOStream/include/ami_sort_impl.h", line 170: error(3254): expected a
          declaration
"./IOStream/include/ami_sort_impl.h", line 218: warning(3109): parsing
    SDEBUG MM_manager.print();
"./IOStream/include/ami_sort_impl.h", line 220: error(3254): expected a
          declaration
    for (size_t i=0; i< nb_runs; i++) {
"./IOStream/include/ami_sort_impl.h", line 241: warning(3109): parsing
      str->write_array(data, crt_run_size);
"./IOStream/include/ami_sort_impl.h", line 242: error(3112): expected a ")"
      assert(str->stream_len() == crt_run_size);
"./IOStream/include/ami_sort_impl.h", line 242: error(3170): this declaration
"./IOStream/include/ami_sort_impl.h", line 245: error(3170): this declaration
      str->name(&strname);
"./IOStream/include/ami_sort_impl.h", line 245: error(3328): variable "str"
          has already been defined
"./IOStream/include/ami_sort_impl.h", line 245: error(3158): expected a ";"
"./IOStream/include/ami_sort_impl.h", line 246: error(3170): this declaration
      runList->enqueue(strname);
"./IOStream/include/ami_sort_impl.h", line 246: error(3158): expected a ";"
"./IOStream/include/ami_sort_impl.h", line 249: error(3170): this declaration
      str->persist(PERSIST_PERSISTENT);
"./IOStream/include/ami_sort_impl.h", line 249: error(3328): variable "str"
"./IOStream/include/ami_sort_impl.h", line 249: error(3158): expected a ";"
"./IOStream/include/ami_sort_impl.h", line 250: error(3254): expected a
          declaration
      delete str;
"./IOStream/include/ami_sort_impl.h", line 251: error(3254): expected a
          declaration
"./IOStream/include/ami_sort_impl.h", line 252: error(3254): expected a
          declaration
"./IOStream/include/ami_sort_impl.h", line 254: error(3254): expected a
          declaration
    delete data;
"./IOStream/include/ami_sort_impl.h", line 256: error(3254): expected a
          declaration
    SDEBUG cout << "runFormation: done.\n";
"./IOStream/include/ami_sort_impl.h", line 257: error(3254): expected a
          declaration
"./IOStream/include/ami_sort_impl.h", line 259: error(3254): expected a
          declaration
    return runList;
"./IOStream/include/ami_sort_impl.h", line 260: error(3254): expected a
          declaration
"./IOStream/include/ami_sort_impl.h", line 285: error(3538): template
          parameter "T" is not used in declaring the argument types of
          function template "singleMerge"
  template<class T, class Compare>
"./IOStream/include/ami_sort_impl.h", line 347: error(3538): template
          function template "multiMerge"
"./IOStream/include/pqheap.h", line 141: error(3114): identifier "bool" is
          undefined
    inline bool full(void);
"./IOStream/include/pqheap.h", line 144: error(3114): identifier "bool" is
          undefined
    inline bool empty(void);
"./IOStream/include/pqheap.h", line 145: error(3114): identifier "bool" is
          undefined
    inline bool is_empty() { return empty(); };
"./IOStream/include/pqheap.h", line 156: error(3114): identifier "bool" is
          undefined
    inline bool min(T& elt);
"./IOStream/include/pqheap.h", line 160: error(3114): identifier "bool" is
          undefined
    inline bool extract_min(T& elt);
"./IOStream/include/pqheap.h", line 163: error(3114): identifier "bool" is
          undefined
    inline bool extract_all_min(T& elt);
"./IOStream/include/pqheap.h", line 166: error(3114): identifier "bool" is
          undefined
    inline bool delete_min();
"./IOStream/include/pqheap.h", line 169: error(3114): identifier "bool" is
          undefined
    inline bool insert(const T& elt);
"./IOStream/include/pqheap.h", line 307: error(3114): identifier "bool" is
          undefined
  inline bool
"./IOStream/include/pqheap.h", line 314: error(3114): identifier "bool" is
          undefined
  inline bool
"./IOStream/include/pqheap.h", line 328: error(3114): identifier "bool" is
          undefined
  inline bool
"./IOStream/include/pqheap.h", line 400: error(3114): identifier "bool" is
          undefined
  inline bool
"./IOStream/include/pqheap.h", line 421: error(3114): identifier "bool" is
          undefined
  inline bool
"./IOStream/include/pqheap.h", line 450: error(3114): identifier "bool" is
          undefined
  inline bool
"./IOStream/include/pqheap.h", line 459: error(3114): identifier "bool" is
          undefined
  inline bool
"./IOStream/include/empq_impl.h", line 43: error(4003): could not open source
          file "ostream.h"
  #include <ostream.h>
89 errors and 1 catastrophic error detected in the compilation of "main.cc".
Compilation terminated.
make: *** [OBJ.mips-sgi-irix6.2/FLOAT/main.o] Error 1
