[GRASS5] r.to.pg: awk question
Hi again,
just now I submitted a script
r.to.pg
into CVS:
src/scripts/contrib/r.to.pg
It allows to write a GRASS raster map into a
one-column table into PostgreSQL. I use it to
analyse large datasets in "R" using the RPgSQL
library (R data proxy).
Following problem I have: Currently the table name
is static: "celltable". I would prefer the map's
name instead. But: As I use awk to generate the
INSERT statements, I have to get the table name
variable into awk. How to do this?
$1: GRASS raster map name
TABLENAME="somestring"
#get the raster values and write out SQL:
r.stats -1 nv='-9999' in=$1 | awk 'BEGIN{}
  NR == 1{}
         {printf "INSERT INTO %s VALUES ( %.5f);\n", $TABLENAME, $1 >> "/tmp/pgimport.sql"}
END{}'
Above printf line is not working, I can just use a hard-coded
"tablename" instead of $TABLENAME. Means: How to use environmental
variables in awk?
Thanks for any advice!
PS: The cat text is not yet supported, but would be a good idea.
subject 'unsubscribe grass5'
Hi Markus,
the awk prog enclosed in '' is not evaluated by the shell so that there
is no substitution of variable names. This would be bad as all other
strings would be evaluated by the shell.
You could echo the program to a temporary file and use awk -f tmpfile.
Or you can supply the string on the awk command line and use "'$1'" to
get it in the awk skript.
Example:
   NR == 1{}
          {printf "INSERT INTO %s VALUES ( %.5f);\n", "'$1'", $1 >>
END{}' $TABLENAME
I did not test this, i personally would use perl or tcl to do that.
hth,
Andreas
Markus Neteler wrote:
Hi again,
r.to.pg
into CVS:
  NR == 1{}
END{}'
variables in awk?
Andreas Lange, 65187 Wiesbaden, Germany, Tel. +49 611 807850
Andreas.Lange@Rhein-Main.de - A.C.Lange@GMX.net
Correct.
Both too complicated.
gawk (which is the standard awk now, derived from the POSIX version of
the new awk) has the ENVIRON field. So you can access environment
variables from within awk. Try awk ' { print ENVIRON["PATH"] } '
(and press return, because awk still reads lines. :slight_smile: )
The second possibility is to use the "-v" flags to bring variables in.
> NR == 1{}
> {printf "INSERT INTO %s VALUES ( %.5f);\n", ENVIRON["TABLENAME"] , $1 >> "/tmp/pgimport.sql"}
> END{}'
Professional Service around Free Software (intevation.net)
The FreeGIS Project (freegis.org)
Correct.
> > NR == 1{}
> > END{}'
Unfortunately my "awk" dislikes the ENVIRON.
Any other ideas? I would be glad to get this into GRASS 5b8.
I try -v var=val --assign=var=val
now.
revisting my pocket reference on awk shows:
ENVIRON["VAR"] only works if you export the variable from the shell
script as follows:
export VAR="somestring"
echo "Test
Test
Test" | awk '{printf "%s: %s\n", ENVIRON["VAR"], $1}'
Not documented, but works for me:
VAR="somestring"
echo "Test
Test
Test" | awk '{printf "%s: %s\n", "'$VAR'", $1}'
hope that clarifies this.
Andreas
Correct.
> > NR == 1{}
> > END{}'
