[GRASS5] r.water.fea tutorial
I have downloaded the tutorial of r.water.fea from http://www.geog.uni-hannover.de/grass/gdp/raster/r_water_fea/ but I can not visualize anything when open it in kghostview (kde ghostview). It seems that there are write nothing in them… only blank pages.
Can someone send me this tutorial or indicate others sites where i can download information about r.water.fea different from html manpage?
Many thanks in advance.
Cristiano G.
On Mon, Feb 05, 2001 at 08:15:24PM +0100, Cristiano G. wrote:
Bereich Geographie – Naturwissenschaftliche Fakultät – Leibniz Universität Hannover but I can
seems that there are write nothing in them... only blank pages. Can
Cristiano G.
Ciao Cristiano,
here it comes fine with "ghostview" and "gv". It seems to be a bug
with kghostview.
You can also generate PDF from it with
ps2pdf
which is distributed with ghostscript (probably already on your machine).
Then
acroread
will work.
Hope this helps
Markus Neteler
subject 'unsubscribe grass5'
On Tue, 6 Feb 2001, Markus Neteler wrote:
You can also generate PDF from it with ps2pdf which is distributed with
ghostscript (probably already on your machine). Then acroread will work.
  FWIW, ps2pdf with ghostscript through 5.5 is of very poor quality. Upgrade
ghostscript to 6.x and the ps2pdf works much better, by several orders of
magnitude.
Rich
Dr. Richard B. Shepard, President
                       Applied Ecosystem Services, Inc. (TM)
              Making environmentally-responsible mining happen. (SM)
            2404 SW 22nd Street | Troutdale, OR 97060-1247 | U.S.A.
+ 1 503-667-4517 (voice) | + 1 503-667-8863 (fax) | rshepard@appl-ecosys.com
