[GRASS5] r3.showdsp-NVIZ
I assume that the "mkdsp" stuff and probably the volume display is
already integrated in above NVIZ/GL versions.
Unfortunatelly, it is not. The volume display is in sg4d which is quite
different from NVIZ but I will try to find it too - it may still
be useful. Mark Astley managed only to write the
interface for linking in r3.showdspf and r3.makedspf but the actual
integration was not done.
So we might not concentrate
an r3.showdspf as a stand-alone module, but try to integrate r3.mkdspf/
r3.showdspf into the NVIZ2.2/openGL. Of course this will be much work.
that is correct, Bill says it should not be too difficult (which does not mean
that it won't be much work). I will try to find everything that could help with it.
Helena
subject 'unsubscribe grass5'
