[GRASS5] r3.showdspf.openGL
Hi!
i finally got r3.showdspf.openGL to compile and run on my system!
The problem was that i needed to compile and install the SGI widgets lib
manually because there is no autoconf in widgets-sgi. The mesa
replacement for the sgi-widgets did'nt produce a shared library.
I updated the README.mesa31 file for those changes. I think Markus could
compile the program because he had a older version of libGLw.so from an
previous installation of mesa.
I don't know if the Gmakefile works, so i send my updated version to
Markus. I had to copy the executable manually to etc/bin/contrib/cmd.
You will need Motif of lesstif and the header files.
See the attached README.mesa31 file for full instruction!
cu
Andreas
Andreas Lange, 65187 Wiesbaden, Germany, Tel. +49 611 807850
Andreas.Lange@Rhein-Main.de, A.C.Lange@GMX.net
(attachments)
README.mesa31 (3.43 KB)
