[GRASS5] raster category confusion
the more I look into the problems of r.average and friends,
the more confused I get.
Simple test (Spearfish):
g.region n=4925010 s=4924770 w=598380 e=598740 nsres=120 ewres=90 -p
r.mapcalc "one=1"
r.info -t one
datatype=CELL
cd spearfish60/neteler/cats
cat one
# 1 categories
0.00 0.00 0.00 0.00
r.cats one
Reading one in neteler ... 100%
99
100
120
156
r.stats -1 one
120
156
99
100
120
156
99
100
r.report one
| #|description |
| 99| |
|100| |
|120| |
|156| |
I am not convinced... Some initialization bug in libgis?
r.mapcalc "one=1"
r.info -t one
datatype=CELL
What do you get without -t?
r.stats -1 one
120
156
99
100
120
156
99
100
That's at odds with the "r.mapcalc one=1", and shouldn't have anything
to do with categories.
Do you have some other mapset in the search path ahead of the current
mapset?
> r.mapcalc "one=1"
> r.info -t one
> datatype=CELL
I get this:
GRASS 6.1.cvs (spearfish60):~/grass61/scripts/v.rast.stats > r.info one
| Layer: one Date: Mon Aug 29 15:32:38 2005 |
| Mapset: neteler Login of Creator: neteler |
| DataBase: /ssi0/ssi/neteler/grassdata |
| Title: ( one ) |
| Type of Map: cell Number of Categories: 1 |
| Data Type: CELL |
| Rows: 2 |
| Columns: 4 |
| Total Cells: 8 |
| Projection: UTM (zone 13) |
| N: 4925010 S: 4924770 Res: 120 |
| E: 598740 W: 598380 Res: 90 |
| Range of data: min = 1 max = 1 |
| Data Source: |
| Data Description: |
| generated by r.mapcalc |
| Comments: |
| 1 |
GRASS 6.1.cvs (spearfish60):~/grass61/scripts/v.rast.stats > g.gisenv
GISDBASE=/ssi0/ssi/neteler/grassdata
LOCATION_NAME=spearfish60
MAPSET=neteler
GRASS_DB_ENCODING=utf-8
DEBUG=0
MONITOR=x0
GRASS_GUI=text
GRASS 6.1.cvs (spearfish60):~/grass61/scripts/v.rast.stats > locate one| grep spearfish60
/hardmnt/thuille0/ssi/grassdata/spearfish60/neteler/cell/one
/hardmnt/thuille0/ssi/grassdata/spearfish60/neteler/cell_misc/one
/hardmnt/thuille0/ssi/grassdata/spearfish60/neteler/cell_misc/one/null
/hardmnt/thuille0/ssi/grassdata/spearfish60/neteler/cell_misc/one/range
/hardmnt/thuille0/ssi/grassdata/spearfish60/neteler/hist/one
/hardmnt/thuille0/ssi/grassdata/spearfish60/neteler/cellhd/one
/hardmnt/thuille0/ssi/grassdata/spearfish60/neteler/cats/one
GRASS 6.1.cvs (spearfish60):/hardmnt/thuille0/ssi/grassdata/spearfish60 > find . -name one
./neteler/cell/one
./neteler/cell_misc/one
./neteler/hist/one
./neteler/cellhd/one
./neteler/cats/one
> r.stats -1 one
> 120
> 156
> 99
> 100
> 120
> 156
> 99
> 100
Right. Looks a bit ugly.
mapset?
GRASS 6.1.cvs (spearfish60):/hardmnt/thuille0/ssi/grassdata/spearfish60 > g.mapsets -p
neteler PERMANENT user1
It seems that there is only this single map gives wrong results.
It's a 32bit RHEL4 box.
> mapset?
The only thing I can suggest is using a debugger.
> > mapset?
To recall, the problem:
r.mapcalc "one=1"
r.cats one
99
100
120
156
Using the debugger, I found that unusual things happen in
G_next_cell_stat() in lib/gis/cell_stats.c
It loops over s->curoffset, and when s->curoffset gets to 35,
then
if ((*count = s->node[s->curp].count[s->curoffset]))
gets true (*count is 2 then, before it was 0).
idx is 16 then.
*cat = (idx<<SHIFT) + s->curoffset;
results in *cat = 99 then (s->curoffset is 35). After that G_next_cell_stat()
is left for the second loop where 100 results and so on.
SHIFT isn't known by the debugger (on top it is defined as 6 ).
I am pretty clueless.
> > > mapset?
r.mapcalc "one=1"
r.cats one
99
100
120
156
Forget about r.cats (and categories in general). This:
r.stats -1 one
120
156
99
100
120
156
99
100
is a lot more interesting (and relevant).
> > > > mapset?
> r.mapcalc "one=1"
> r.cats one
> 99
> 100
> 120
> 156
> r.stats -1 one
> 120
> 156
> 99
> 100
> 120
> 156
> 99
> 100
OK:
in r.stats:
main.c
G_get_range_min_max (&range, &min, &max);
min =1
max =1
ok so far.
raw_stats (fd, verbose, with_coordinates, with_xy, with_labels);
           fd 0 0 0 0
Entering raw_stats():
raw_stats.c:49
rastp[i] = rast[i];
i=0
rastp[0]= void
raw_stats.c:98, when i is 0, then
*((CELL *) rastp[i]) is 120.
Then it prints 120 and so forth.
Should I add some G_debug() in raw_stats?
> > r.stats -1 one
> > 120
> > 156
> > 99
> > 100
> > 120
> > 156
> > 99
> > 100
OK:
in r.stats:
main.c
min =1
max =1
ok so far.
           fd 0 0 0 0
raw_stats.c:49
rastp[i] = rast[i];
i=0
rastp[0]= void
I'd start by examining the pointers rastp[0] and rast[0], and the
contents of the buffer to which they point, before entering the
"for (col = ..." loop. I.e.:
  print rast[0]
  print rastp[0]
  print *(CELL*)(rast[0])@50
> > > r.stats -1 one
> > > 120
> > > 156
> > > 99
> > > 100
> > > 120
> > > 156
> > > 99
> > > 100
> OK:
> in r.stats:
> main.c
> min =1
> max =1
> ok so far.
> fd 0 0 0 0
> raw_stats.c:49
> rastp[i] = rast[i];
> i=0
> rastp[0]= void
  print rast[0]
  print rastp[0]
The @ is dislike (not sure what it does). This is what I get:
GRASS 6.1.cvs (spearfish60):~/grass61/raster/r.stats > cvs diff raw_stats.c
Index: raw_stats.c
RCS file: /grassrepository/grass6/raster/r.stats/raw_stats.c,v
retrieving revision 2.1
diff -u -r2.1 raw_stats.c
--- raw_stats.c 13 Jul 2005 15:55:40 -0000 2.1
+++ raw_stats.c 1 Sep 2005 13:10:08 -0000
@@ -52,6 +52,11 @@
        if (with_coordinates)
            G_format_northing (G_row_to_northing(row+.5, &window), nbuf, -1);
+ G_debug(0, "rast[%d]: %d", rast[i], i);
+ G_debug(0, "rastp[%d]: %d", rastp[i], i);
+ G_debug(0, "*(CELL*)(rast[0]): %d", *(CELL*)(rast[0]));
+ G_debug(0, "*(CELL*)(rast[%d]): %d", *(CELL*)(rast[i]));
        for (col = 0; col < ncols; col++)
            if (no_nulls || no_nulls_all)
GRASS 6.1.cvs (spearfish60):~/grass61/raster/r.stats > r.stats -1 one
D0/0: rast[0]: 1
D0/0: rastp[0]: 1
D0/0: *(CELL*)(rast[0]): 120
Segmentation fault
Apparently the last G_debug does not make sense, but the mysterious (?) 120
is there.
BTW:
gcc version 3.4.3 20050227 (Red Hat 3.4.3-22.1)
I just see that the damn optimization creeped in again.
When I do
CFLAGS="-g -Wall" ./configure ...
checking host system type... i686-pc-linux-gnu
checking for gcc... gcc
checking whether the C compiler (gcc -g -Wall ) works... yes
checking whether the C compiler (gcc -g -Wall ) is a cross-compiler... no
C compiler: gcc -g -Wall
C++ compiler: c++ -g -O2
But:
grep CFLAGS_OPTIMIZE ~/grass61/include/Make/Platform.make
CFLAGS_OPTIMIZE = -O2
I have to manually fix that. Seems to be evil in aclocal.m4
around line 756:
        Linux*)
            SHLIB_CFLAGS="-fPIC"
            SHLIB_LD_LIBS='${LIBS}'
            SHLIB_SUFFIX=".so"
            CFLAGS_OPTIMIZE=-O2
            # egcs-2.91.66 on Redhat Linux 6.0 generates lots of warnings
            # when you inline the string and math operations. Turn this off to
            # get rid of the warnings.
            #CFLAGS_OPTIMIZE="${CFLAGS_OPTIMIZE} -D__NO_STRING_INLINES -D__NO_MATH_INLINES"
The r.stats debug result remains however the same.
To separate the threads, I repost it again:
When I do
But:
around line 756:
        Linux*)
            SHLIB_SUFFIX=".so"
            CFLAGS_OPTIMIZE=-O2
Paul, do you remember the reason for this modification?
http://grass.itc.it/pipermail/grass-commit/2004-July/012136.html
> > > > r.stats -1 one
> > > > 120
> > > > 156
> > > > 99
> > > > 100
> > > > 120
> > > > 156
> > > > 99
> > > > 100
> > OK:
> > in r.stats:
> > main.c
> > min =1
> > max =1
> > ok so far.
> > fd 0 0 0 0
> > raw_stats.c:49
> > rastp[i] = rast[i];
> > i=0
> > rastp[0]= void
> print rast[0]
> print rastp[0]
Index: raw_stats.c
@@ -52,6 +52,11 @@
D0/0: rast[0]: 1
D0/0: rastp[0]: 1
Segmentation fault
is there.
BTW:
OK, we debugged some more hours here. Outcome:
With apparently identical settings (PATH, LD_LIBRARY_PATH etc),
identical software (GRASS, libs etc), identical shell:
- user 'neteler' still writes/reads nonsense raster maps
- another user on the same machine successfully writes/reads raster
  maps except for those generated by user 'neteler'
It seems that I am out of the game :slight_smile:
Crazy.
Hello Markus
On Fri, 2 Sep 2005, Markus Neteler wrote:
            CFLAGS_OPTIMIZE=-O2
I don't think that is relevant as CFLAGS_OPTIMIZE isn't actually used anywhere (to answer your question it was copied from the most recent version in the Tcl/Tk source at the time and seemed to work well so I re-used it).
I suspect the -O2 is being added in automatically by autoconf at some stage. Search for -O2 in the configure script and you will see there are some occurences that are not sourced from either configure.in nor aclocal.m4.
You could manually edit the configure script after editing it perhaps: this
looks very suspicious:
echo "$ac_t""$ac_cv_prog_cxx_g" 1>&6
if test "$ac_test_CXXFLAGS" = set; then
   CXXFLAGS="$ac_save_CXXFLAGS"
elif test $ac_cv_prog_cxx_g = yes; then
   if test "$GXX" = yes; then
     CXXFLAGS="-g -O2"
   else
     CXXFLAGS="-g"
   fi
else
     CXXFLAGS="-O2"
   else
     CXXFLAGS=
   fi
fi
but I suspect the more robust solution is to explicitly set CXXFLAGS as well as CFLAGS, i.e. something like:
CFLAGS="-g -Wall" CXXFLAGS="-g -Wall" ./configure ...
Does that work?
Paul
Hello Paul,
On Fri, Sep 02, 2005 at 03:09:26PM +0100, Paul Kelly wrote:
Hello Markus
>> CFLAGS_OPTIMIZE=-O2
>> off to
anywhere
good point, I didn't realize that (so, false alarm).
re-used it).
aclocal.m4.
    CXXFLAGS="-g -O2"
  else
    CXXFLAGS="-g"
  fi
else
    CXXFLAGS="-O2"
  else
    CXXFLAGS=
  fi
fi
Does that work?
Yep:
grep 'O2\|CFLA' include/Make/Platform.make
CFLAGS_DEBUG = -g
CFLAGS_WARNING = -Wall -Wconversion -Wno-implicit-int
SHLIB_CFLAGS = -fPIC
CFLAGS1 = -g -Wall
COMPILE_FLAGS = $(CPPFLAGS) $(CFLAGS1) $(CFLAGS_WARNING) $(INCLUDE_DIRS)
XCFLAGS = -I/usr/X11R6/include
GDALCFLAGS = -I/usr/local/include
PROJINC = $(GDALCFLAGS)
> > raw_stats.c:49
> > rastp[i] = rast[i];
> > i=0
> > rastp[0]= void
> print rast[0]
> print rastp[0]
The above are gdb commands. Appending @<n> to a value in a gdb print
statement prints <n> elements.
Index: raw_stats.c
@@ -52,6 +52,11 @@
The arguments are the wrong way around.
D0/0: rast[0]: 1
D0/0: rastp[0]: 1
These two say that rast[1] == rastp[1] == 0 (i.e. NULL). I would have
expected to see values for rast[0].
When I do
But:
around line 756:
Right. Both CFLAGS_OPTIMIZE and CFLAGS_WARNING are bogus. Any compiler
switches which aren't essential (e.g. include directories) should be
left up to the user.
The simplest solution is to remove them from include/Make/*.make[.in].
