I have a set of scanned maps that I want to georectify. However I am unsure of the most efficient way to handle the three images (three color bands) associated with each image. I have imported them into a temporary xy location and can display with d.rgb (takes about 10 seconds to display). I have grouped all with i.group, and used i.target to set up new target location and mapset. Now I am ready to use i.points. My question is this: Since it looks like all three element maps (rgb) need to have i.points run with associated coordinates, should the three elements of the color table me merged first in order to reduce the number of maps that need georeferencing, or is assigning coordinates to all three bands the standard approach? I read in "Open Source GIS: A Grass GIS Approach (Neteler and Mitsova) that one of the reasons that scanned color maps are broken into color bands is to reduce computational overhead and there by speed up image processing. Does it make sence to merge these maps first in order to reduce number of maps that need georectifying, or would I be more than paying for that time savings with very slow image processing?
btw... using grass5.7
Thanks
Kirk
Kirk R. Wythers tel: 612.625.2261
Dept. of Forest Resources fax: 612.625.5212
University of Minnesota email: kwythers@umn.edu
