two problems are remaining for the MAN page creation in 5.7:
1) this error:
cd man
make
Converting: xganim.html to /home/neteler/soft/57grass_cvsexp/dist.i686-pc-linux-gnu/man/man1/xganim.1
/bin/sh: line 1: [: too many arguments
make[1]: Leaving directory `/home/neteler/soft/57grass_cvsexp/man'
I don't know why and where it appears in the Makefile.
2) Currently the path to PERL is hardcoded in
scripts/g.html2man/g.html2man
I would like to use the original 5.3 approach to use $(GRASS_PERL)
and the initial lines of
grass5/src/scripts/contrib/g.html2man/g.html2man
but I don't get that working in man/Makefile...
Help/cvs fixes welcome
thanks
1) this error:
cd man
make
Please start from mk/Makefile.docs in 5.3, not html/Gmakefile.
If you want to generate a file only if it doesn't exist or if it is
older than its source file, use "make" (as opposed to writing a
mini-make using /bin/sh and getModTime).
Also, g.html2man should probably go into the "tools" directory rather
than "scripts", as it's only used when compiling.
> 1) this error:
> cd man
> make
I've changed man/Makefile accordingly; it seems to work OK.
> 1) this error:
> cd man
> make
Oops. Good point.
I was sort of distracted by the html/Gmakefile approach.
Thanks for fixing the Makefile.
Done.
