> > I was thinking
> > mv grass51 grass6
> > ln -s grass6 grass51
Done now!
CVS access is reenabled.
I switched off grass51 in the viewcvs interface to avoid=20
showing the same module twice.=20
I hope links will also be corrected then, because they fail.
For fresh checkouts: Use module grass6 now.
For old checkouts: You can continue using grass51,
no need to do a complete recheck in at this time.
Thanks for the change. It works well.
We could experiment with scripts changing the CVS/Root file contents.
Find attached the script doing this job.
Usage:
1. Go to GRASS 6 CVS source code main directory, store the attached
script there, then use 'find' to launch the script:
cd grass6src_cvs/
find . -name 'Repository' -exec sh change-repository.sh {} \;
Note that:
G_asprintf( &colorstring, "%s", db_get_string(&valstr) );
would also work but no need to complicate things further than G_store() as you're just copying one string to another.
Then (after the last time you've used colorstring):
G_free(colorstring);
Should be freed if either G_store() or G_asprintf() have been used.
