Brian,
(cc grass5 list)
On Fri, Jul 19, 2002 at 10:22:41AM -0400, Perrault, Brian wrote:
Markus,
When you first get to the LOCATION : MAPSET: DATABASE: screen in
grass5, is there another way to do a "esc + enter"??The reason I ask is because I finally got everything setup and going
with Xwin on my Zaurus, but there isn't an "esc" key. Furthermore, the
keymapping doesn't provide a combo of keys which maps to esc.
you can skip the entry screen like this:
grass5 /path_to_grassdatabase/location/mapset
But: All interactive modules require the ESC key. Maybe we should
add an environmental variable:
GRASS_REMAP_ESC_KEY
to allow for easy key remapping? I don't know if that is easy
to implement. What do the other developers say?
-----Original Message-----
Sent: Tuesday, June 18, 2002 8:23 AM
To: Perrault, Brian
Cc: grass-bugs@intevation.de
Subject: Re: [bug #1118] (grass) Grass on ZaurusOn Tue, Jun 18, 2002 at 08:08:40AM -0400, Perrault, Brian wrote:
> Markus,
> I got Grass GIS working. I just needed to add libz.so.1 and
> libncurses.so.5. The other problem is that for some reason, on the
Zaurus,
> you can't unpack the archive libraries (the ones mentioned above) to their
> default location. Instead I had to do a "ipkg -d *some other location*
> libncurses5". Not sure why this was, it happened even when I was root.
> Anyhow, since there may be other Zaurus/Embedix people out there, it
> would be great if you could have an aside or a note for Zaurus users. No
> need to reinvent the wheel.
> Let me know what you think.Brian,
congratulations! It would be good to have such note. Since I do not
have a Zaurus/Embedix, may I ask you to send me a short text plugin for
the web pages?Thanks,
> From: Markus Neteler [mailto:neteler@itc.it]
> Sent: Tuesday, June 18, 2002 2:39 AM
> To: Perrault, Brian
> On Mon, Jun 17, 2002 at 12:45:48PM -0400, Perrault, Brian wrote:
> > Markus,
> > Where might one acquire such libraries as "libz.so.1" ???
> Here:
> http://www.gzip.org/zlib/
> Brian, are you sure that Zaurus is 100% identical to iPAQ?
> I don't know anything about that, but just curious.
> Markus
> > Sent: Friday, June 14, 2002 6:27 PM
> > To: Perrault, Brian
> > Cc: Request Tracker
> > Brian,
> > On Fri, Jun 14, 2002 at 05:36:25PM -0400, Perrault, Brian wrote:
> > > Markus,
> > > Greetings. Thank you for your prompt response. It looks like what
> > > you guys have for the Ipaq is different from what Baylor has.
> > it appears continuously, that Baylor is behind. Note that the
> > main site is:
> > http://grass.itc.it
> > I have no idea how to convince Baylor to maintain their site better.
> > So far I am trying for 2 years now.
> > > here they are :http://www3.baylor.edu/grass/grass5/binary/ipaq_linux/
> > > here you are :http://grass.itc.it/grass5/binary/ipaq_linux/
> > > Notice the file sizes. For what it is worth, I tried to use the
gzipped
> > tar
> > > format (from Baylor also), and when I got it out of the archive, fixed
> the
> > > path as instructed, and tried to run it, I got the follwing:
> > which path?
> > > First, the welcome screen came up as usual, with the three notes
> > > 1) Have at your side....
> > > 2) When working on your location....
> > > 3) Check the GRASS webpage....
> > > hit RETURN to continue....
> > > When I hit return, I get this error;
> > > <path>/dist.armv4l-unknown-linux-gnu/etc/set_data: error while loading
> > > shared libraries: libz.so.1: cannot load the shared object file: No
such
> > > file or directory.
> > you have to install libz. That's a system library providing compression
> > algorithm.
> > > So it looks like neither of the files I got from Baylor are
working.....
> > No, your systemInstall that lib and it will work.
> > Good night,
> > Markus
> > > From: Markus Neteler via RT [mailto:grass-bugs@intevation.de]
> > > Sent: Friday, June 14, 2002 4:51 PM
> > > To: perraultb@ll.mit.edu
> > > Subject: [bug #1118] (grass) Grass on Zaurus
> > > On Fri, Jun 14, 2002 at 09:47:53PM +0200, Request Tracker wrote:
> > > > this bug's URL: http://intevation.de/rt/webrt?serial_num=1118
> > > > Subject: Grass on Zaurus
> > > > Platform: other
> > > > grass obtained from: Other (CDROM etc)
> > > > grass binary for platform: Downloaded precompiled Binaries
> > > > GRASS Version: 5.0pre4
> > > > Trying to install Grass GIS for my Sharp Zaurus using the Ipaq/Linux
> > > binary I got from Baylor University
> > > > when I use Terminal and try the "ipkg install" command, here's what
I
> > get:
> > > > zcat: grass_5.0.0-20020507-1_arm.ipk: invalid compressed
data--format
> > > violated
> > > > tar: Unexpected EOF in archive
> > > > tar: Error exit delayed from previous errors
> > > This looks like a transmission error, because:
> > > tar tvfz grass_5.0.0-20020507-1_arm.ipk
> > > -rw-rw-r-- root/root 4 2002-05-07 17:06:15 ./debian-binary
> > > -rw-rw-r-- root/root 556483 2002-05-07 17:06:15 ./data.tar.gz
> > > -rw-rw-r-- root/root 522 2002-05-07 17:06:15 ./control.tar.gz
> > > is fine (at least on
> > > > zcat: stdin: unexpected end of file
> > > > ipkg_install_file: ERROR unpacking control.tar.gz from
> > > > Thank you in advance for any advice you can provide
> > > You may try again from ITC.
> > > Markus
> > > --- Headers Follow ---
> > > >From neteler@itc.it Fri Jun 14 22:50:29 2002
> > > Return-Path: <neteler@itc.it>
> > > Delivered-To: grass-bugs@lists.intevation.de
> > > Received: from mail.intevation.de (aktaia [212.95.126.10])
> > > by lists.intevation.de (Postfix) with ESMTP id 29E9D13965
> > > for <grass-bugs@lists.intevation.de>; Fri, 14 Jun 2002 22:50:29
> > > +0200 (CEST)
> > > Received: from camelot.itc.it (camelot.itc.it [195.223.171.5])
> > > by mail.intevation.de (Postfix) with ESMTP id 12A7D1B6D9
> > > for <grass-bugs@intevation.de>; Fri, 14 Jun 2002 22:50:26 +0200
> > > (CEST)
> > > Received: from orchestra.itc.it (orchestra [10.0.10.11])
> > > by camelot.itc.it (8.11.3/8.11.3) with ESMTP id g5EKoOn10983
> > > for <grass-bugs@intevation.de>; Fri, 14 Jun 2002 22:50:24 +0200 (MET
> > > DST)
> > > Received: from thuille.itc.it. (thuille [10.40.0.110])
> > > by orchestra.itc.it (8.11.6/8.11.6) with ESMTP id g5EKoNK20976;
> > > Fri, 14 Jun 2002 22:50:23 +0200
> > > Received: (from neteler@localhost)
> > > by thuille.itc.it. (8.11.6/8.11.2) id g5EKoN431369;
> > > Date: Fri, 14 Jun 2002 22:50:23 +0200
> > > From: Markus Neteler <neteler@itc.it>
> > > To: Request Tracker <grass-bugs@intevation.de>
> > > Cc: grass5@grass.itc.it
> > > Subject: Re: [GRASS5] [bug #1118] (grass) Grass on Zaurus
> > > Message-ID: <20020614225023.A31365@itc.it>
> > > Mail-Followup-To: Request Tracker <grass-bugs@intevation.de>,
> > > grass5@grass.itc.it
> > > References: <20020614194753.DD22A139C6@lists.intevation.de>
> > > Mime-Version: 1.0
> > > Content-Type: text/plain; charset=us-ascii
> > > Content-Disposition: inline
> > > User-Agent: Mutt/1.2.5.1i
> > > In-Reply-To: <20020614194753.DD22A139C6@lists.intevation.de>; from
> > > grass-bugs@intevation.de on Fri, Jun 14, 2002 at 09:47:53PM +0200
> > > X-Spam-Status: No, hits=-4.4 required=5.0 tests=IN_REP_TO version=2.20
> > > X-Spam-Level:
> > > -------------------------------------------- Managed by Request
Tracker
> > Markus Neteler
> > ITC-irst, Istituto per la Ricerca Scientifica e Tecnologica
> > Project on Predictive Models for the Environment
> > Via Sommarive, 18 - 38050 Povo (Trento), Italy
> > tel +39 0461 314 -520 (fax -591) http://mpa.itc.it
> Markus Neteler
> tel +39 0461 314 -520 (fax -591) http://mpa.itc.it--
Markus NetelerITC-irst, Istituto per la Ricerca Scientifica e Tecnologica
Markus Neteler
