below mail I got today. Can we do anything for Luis and his Zaurus?
On Thu, Sep 05, 2002 at 08:21:45PM -1000, Luis aka Rigpa wrote:
The hurdle I have is dealing with the esc key. I have tried to do the
/GRASS location command thing and for some reason baby GRASS refuses to
acknowleg it. It always asks for an interactive startup. As you know
the interactive startup requires a esc/enter sequence. On Zaurus/Qtopia
esc exits the application, so when I press 'esc' it quits VNC. :P~~~~That's why I tried the GRASS /location thing but it refuses to work. Any
ideas of a workaround? You had mentiones on a post adding a map-key
option to GRASS,but I don't think anything ever came of that. Any ideas?
Ctrl-[ doesn't work ether since the Ctrl key is required in order to do a
[ on the Zaurus.
Ref's are:
http://grass.itc.it/pipermail/grass5/2002-July/003606.html
http://grass.itc.it/pipermail/grass5/2002-July/003608.html
