On Wed, Aug 14, 2002 at 02:03:15PM +0200, Glynn Clements via RT wrote:
Request Tracker wrote:
> this bug's URL: http://intevation.de/rt/webrt?serial_num=1231
> Hi,
> it seems that g.copy doesn't completely cop a map.
> At least the range file in cell_misc/ is ignored:
> E.g. current mapset 'modis', I am copying from 'PERMANENT' into
> 'modis':
> GRASS:~ > l ~/grassdata/pat/PERMANENT/cell_misc/geologia/
> total 4
> -r--r--r-- 1 merler ssi 10 Jul 20 1998 range
> GRASS:~ > g.copy geologia,test
> COPY [geologia@PERMANENT] to [test]
> raster
> header
> category
> color
> history
> misc
> fcell MISSING
> g3dcell MISSING
> GRASS:~ >l ~/grassdata/pat/PERMANENT/cell_misc/test
> ls: /ssi0/ssi/neteler/grassdata/pat/PERMANENT/cell_misc/test: No such file or
> directoryEr, shouldn't this be "modis" instead of "PERMANENT"?
Er, yes. Sorry, but....
AFAICT, g.copy *does* copy the cell_misc/<map> directory (assuming
that it's in etc/element_list).
You are right. The problem is still there, but different:
GRASS:~ > l /ssi0/ssi/neteler/grassdata/pat/neteler/cell_misc/test
total 4
-r--r--r-- 1 neteler ssi 10 Aug 14 14:25 range
GRASS:~ > r.support -r test
Updating the stats for [test]
WARNING: can't write range file for [test in neteler]
Updating the number of categories for [test]
The permissions should be
-rw-r--r--
right? That's the real problem where I was struggling.
> I feel that this should be fixed for 5.0.0 since the cell_misc
> may also contain histogram, reclassed_to and null.Note that g.copy explicitly removes the reclassed_to file. This is
correct; however:1. The code is part of cmd/copy.c, whereas the code to remove the
colr2 file is in lib/do_copy.c.2. It uses sprintf/system ("rm -f ..."), rather than G_remove().
Brrr...
