d.zoom segfaults direct after startup without any message.
region is :
CURRENT REGION: N=431250 S=350000 RES=250 ROWS=325
E= 80000 W= 13000 RES=250 COLS=268
It seems the bug was caused by a library call in
src/libes/gis/find_file.c. A string was copied to an empty string wich
caused the segfault.
The solution (or: my solution) is the following diff for find_file.c. I
can submit it to the CVS but I don't like to mess with libraries and I
don't know if there is a 'philosophy' behind the original method.
54c54,56
< strcpy(mapset, xmapset);
if (!mapset=="") {
Grtz, Job
Job Spijker
Faculty of Geographical Sciences, Utrecht University
subject 'unsubscribe grass5'
Sorry about my previous post -- I intended to send it to Job in
private, but overlooked the Reply-To field. Now I owe you a translation:
you changed src/libes/gis/find_file.c recently to fix the
i.in.erdas. Do you have a recommendation for below proposal
from Job?
Thanks
On Tue, Mar 20, 2001 at 01:07:01PM +0100, spijker@geo.uu.nl wrote:
> region is :
Job Spijker
From neteler@geog.uni-hannover.de Wed Mar 21 02:21:02 2001
Date: Tue, 20 Mar 2001 17:45:00 +0000
From: Markus Neteler <neteler@geog.uni-hannover.de>
To: grass5@geog.uni-hannover.de
Subject: Re: [GRASS5] Re: [bug #223] (grass) d.zoom segfaults
Hi Huidae,
from Job?
Thanks
> > region is :
> 54c54,56
> > if (!mapset=="") {
Hi Markus,
I see. I'm correcting it.
Huidae Cho
> 54c54,56
> > if (!mapset=="") {
Be careful about comparing mapset directly to ""; please try the
example program below to see why.
A more defensive solution might be:
if (mapset != NULL && *mapset != '\0') {
(it doesn't need to know whether mapset is a character array or a
pointer to a character).
Edzer
Markus Neteler * University of Hannover
Institute of Physical Geography and Landscape Ecology
Schneiderberg 50 * D-30167 Hannover * Germany
Tel: ++49-(0)511-762-4494 Fax: -3984
