voice: 480-965-6262; fax: 480-965-7671
On May 13, 2004, at 2:00 AM, Markus Neteler via RT wrote:
Michael,
did you create a vector entry first in 'd.m'? And activated the layer?
Then the 'dig' item should work.
I will try this. Does it work for creating new vectors (i.e., can I create a blank vector entry)? This is what I was trying to do.
When v.digit started from command line, the background commands still don't work--though they give a different error than they used to. Now they generate...
v.digit map=elevation_mask bgcmd=d.rast map=elevation_dem -n
You are missing the quotes:
v.digit map=elevation_mask bgcmd='d.rast map=elevation_dem' -n
I did this. I tried both single and double quotes. Same result.
Michael
______________________________
Michael Barton, Professor & Curator
School of Human Origins, Cultures, & Societies
Arizona State University
Tempe, AZ 85287-2402
USA
