On 8/31/05, Markus Neteler via RT <grass-bugs@intevation.de> wrote:
> When a Tcl/Tk GUI run module exits with an error becasue the output file
> already exists (need to use --o), it doesn't have a red (X) icon before the
> error message. Why not?
Ciao Radim,
could you fix that? Not sure what's missing...
Thanks
The problem is that G_fatal_error() must be used to get an error message
formated for GUI. Unfortunately G_fatal_error() calls exit() and G_parser()
must not exit. G_set_error_routine() does not help because in that case
G_fatal_error() prints nothing.
Radim
