Subject: [bug #3023] (grass) r.fillnulls doesn't work
this bug's URL: http://intevation.de/rt/webrt?serial_num=3023
>> I'm reffering here to a single 3" SRTM tile loaded using r.in.srtm.
>> r.fillnulls works very long and uses so much swap that mouse stops
>> answering, temporarily, after several minutes....?
GRASS 6.0.cvs:~ > g.region rast=N51E016 -ap
projection: 3 (Latitude-Longitude)
zone: 0
datum: wgs84
ellipsoid: wgs84
north: 52:00:01.5N
south: 50:59:58.5N
west: 15:59:58.5E
east: 17:00:01.5E
nsres: 0:00:03
ewres: 0:00:03
rows: 1201
cols: 1201
looks ok.
GRASS 6.0.cvs:~ > g.region -g
n=52.00041667
s=50.99958333
w=15.99958333
e=17.00041667
nsres=0.00083333
ewres=0.00083333
that looks ok too. The buffer distance is supposed to be nsres+ewres.
This was fixed to work with floating point resolutions (i.e. lat/lon)
before 6beta2 was released.
> I've just added some more error checking in CVS, can you update and
> try again? maybe uncomment "echo RES=.." line?
> (It won't fix your problem but will stop the script if this step
> fails.)
then run "make" from within the modules' directory. (+ install?)
both scripts have new bugfixes and extra checks. can you test them?
Ok, I dowlnloaded them but didn't rebuild, just copied into my Grass6 directory. These are scripts, I don't have to rebuild, right?
r.in.srtm works ok now, thanks.
r.fillnulls fails in such a way:
GRASS 6.0.cvs:~ > r.fillnulls input=N51E016_nowy output=N51E016_nowy.fld
Using tmp file r_fillnulls_4707
Locating and isolating NULL areas...
100%
r.buffer: 00000000 - illegal distance specification
Description:
Creates a raster map layer showing buffer zones surrounding cells that contain
non-NULL category values.
Usage:
r.buffer [-qz] input=value output=name distances=value[,value,...]
[units=name]
Flags:
-q Run quietly
-z Ignore zero (0) data cells instead of NULL cells
Parameters:
input Name of input map
output Name of output map
distances Distance zone(s)
units Units of distance
options: meters,kilometers,feet,miles,nautmiles
default: meters
ERROR detected: /usr/local/grass-6.0.cvs/scripts/r.fillnulls abandoned. Removing temporary map:
REMOVE [r_fillnulls_4707]
raster
header
category
color MISSING
history
misc
fcell MISSING
g3dcell MISSING
ERROR: <mask_4707> not found
my region was:
GRASS 6.0.cvs:~ > g.region rast=N51E016_nowy -ap
zone: 0
datum: wgs84
ellipsoid: wgs84
north: 52:00:01.5N
south: 50:59:58.5N
west: 15:59:58.5E
east: 17:00:01.5E
nsres: 0:00:03
ewres: 0:00:03
rows: 1201
cols: 1201
.. pretty much everything will be broken after the r.buffer step fails.
Please try again with the two updated scripts.
As you said...
Maciek
