Hi Morten,
On Mon, Mar 28, 2005 at 05:21:31PM +0200, Morten Hulden wrote:
Hi Markus,
as I could not get write access to the cvs (public key failed) I submit
@ Bernhard: could you fix that for Morten?
this patch to you directly as a diff file. To apply the patch you should
go into the directory where your grass6 sources are stored
(/usr/local/src/grass/grass6 in my case) and issuepatch -p1 < /path/to/r.proj-20050328mhu.patch
This patch fixes two things:
-assymetric integer truncation error [bug #3100]
-adds a missing offset to the initial x-coodinate for each row in the
main projection loop. this offset causes the projection of the _center_
of the cell instead of the border. this was always the intention but
earlier it was only made correctly for the first row of the location.A set of test maps provided by Maciek Sieczka helped to spot the bugs.
I have applied the bug fixes to
- CVS 6.1
- 6.0 release branch
Thanks for fixing it,
