[GRASS5] Re: [bug #4155] (grass) d.m will not display remotely
On Mar 8, 2006, at 10:05 PM, Glynn Clements via RT wrote:
Request Tracker wrote:
this bug's URL: http://intevation.de/rt/webrt?serial_num=4155
Subject: d.m will not display remotely
Platform: Mac OSX
grass obtained from: CVS
GRASS Version: 6.1.cvs
d.m is no longer displaying when started remotely through ssh -X. d.mon x0 seems ok, it fires up
the expected display window with the message:
GRASS 6.1.cvs (minnesota_utm):~ > d.mon x0
using default visual which is TrueColor
ncolors: 16777216
Graphics driver [x0] started
However, d.m or d.m & result in the following message:
GRASS 6.1.cvs (minnesota_utm):~ > X Error of failed request: BadAtom (invalid Atom parameter)
  Major opcode of failed request: 20 (X_GetProperty)
  Atom id in failed request: 0xb5
  Serial number of failed request: 11
  Current serial number in output stream: 11
For what it is worth gis.m seems to behave in the same mannor:
GRASS 6.1.cvs (minnesota_utm):~ > gis.m
I'm guessing that this is an issue with "wish". It's impossible to say
any more than that based upon the above details; atom 0x5b (91) isn't
predefined (only 1 through 68 are predefined).
Can you run wish by itself (or any other Tcl/Tk programs) remotely?
I hate to have to sound this stupid but you can't hide from the truth...
I'm not sure what you mean by run wish. I tried the following:
truffula:/usr/include kwythers$ wish8.4
   Major opcode of failed request: 18 (X_ChangeProperty)
   Serial number of failed request: 12
   Current serial number in output stream: 15
If that is what you meant, it looks to be the same error as d.m gave from GRASS.
Also, can you suggest a simple tcltk program to try remotely (an equivalent to xclock)?
from GRASS.
That's exactly what I meant.
Not offhand, although that is no longer necessary.
The problem applies to running wish (the Tcl/Tk interpreter), and will
affect all Tcl/Tk programs. There isn't anything that d.m or gis.m can
do to work around it.
