[GRASS5] Re: [bug #750] (grass) g.manual problem
Hi Markus
Markus Neteler via RT wrote:
here it works fine. Be sure that you have eliminated the (old) binary
version of g.manual. Check
which g.manual
/usr/local/grass5/scripts/g.manual
that you use the script version. What does
echo $GRASS_PAGER
more
tell you?
The following is a sample run from Grass built yesterday from an update
of the release branch, followed by
make uninstall
make clean
make
make install
Note that this was obtained by selecting the text on the terminal
window, and then pasting it in my mail composer window.
Mapset <PERMANENT> in Location <jhickey>
GRASS 5.0.0pre1 > g.manual -1
GRASS 5.0.0pre1 > which g.manual
/tmp/grass/grass5/scripts/g.manual
GRASS 5.0.0pre1 > echo $GRASS_PAGER
more
GRASS 5.0.0pre1 > g.manual -a
GRASS 5.0.0pre1 >
As you can see, the -1 and -a options do nothing for me. I haven't had
time to look at this yet, any hints on where to start?
Sincerely,
Jazzman (a.k.a. Justin Hickey) e-mail: jhickey@hpcc.nectec.or.th
High Performance Computing Center
National Electronics and Computer Technology Center (NECTEC)
Bangkok, Thailand
People who think they know everything are very irritating to those
of us who do. ---Anonymous
Jazz and Trek Rule!!!
g.manual fails if PAGER is unset:
  if [ "$opt1" ]
  then
    /bin/ls $GISBASE/man/man1 | $PAGER
    exit 0
  elif [ "$opta" ]
  then
    /bin/ls -C $GISBASE/man/man1 | $PAGER
    exit 0
  fi
This needs to be changed to $GRASS_PAGER; presumably the global change
of PAGER to GRASS_PAGER overlooked the scripts.
Hi Glynn
> had time to look at this yet, any hints on where to start?
  if [ "$opt1" ]
  then
    exit 0
  elif [ "$opta" ]
  then
    exit 0
  fi
change of PAGER to GRASS_PAGER overlooked the scripts.
Yep, you're right. That was it. Thanks for the fix. I'll update the CVS
tree and I checked for other instances of PAGER in src/scripts but did
not find any.
Thanks again.
Sincerely,
Bangkok, Thailand
