On Sat, 17 Jun 2000 16:22:48, Markus Neteler writes:
Several string attributes are not read correctly,
if *spaces* occur within the strings (even if
@"substringA substringB" is used).
Around line 866, in the function next_att(), you will find your
culprit. next_att() splits attributes apart at spaces, regardless
of the quoting. Apparently, this allows multiple attributes on a
single line. Maybe there should be commas between them, or something.
Otherwise, the next_att() function will have to keep track of the
quoting status: this starts to get ugly.
Bill Hughes
subject 'unsubscribe grass5'
