Subject: [GRASS5] bug in configure routine
I just experienced a small bug in the configure routine:
[jan@mimirs grass]$ ./configure --help
Directory and file names:
--prefix=PREFIX install architecture-independent files in PREFIX
[/usr/local/grass-5.0b]
--exec-prefix=EPREFIX install architecture-dependent files in EPREFIX
[same as prefix]
--bindir=DIR user executables in DIR [EPREFIX/bin]but AC_BINDIR_DEFAULT is /usr/local/bin and keeps this default
no matter what I specifiy for prefix.Not a big deal, but should be straightened somehow.
Jan
Hmm, yes you're right. You can use --with-bindir instead of --bindir.
$bindir, created by --bindir, is not used though defined.
$BINDIR, created by --with-bindir, is used instead.
So i suggest to remove --bindir and other unused options of configure.
Any objection?
Huidae Cho
subject 'unsubscribe grass5'
