[GRASS5] Re: Compiling on Solaris
Hi Justin, hi all,
On Thu, Oct 19, 2000 at 12:21:26PM +0700, Justin Hickey wrote:
Hi Markus
Markus Neteler wrote:
> at time I am trying to compile GRASS on our SUN. But
> I get tons of
> /data3/grass5/grass/src/CMD/gmake5.0: test: argument expected
> Do you have any idea for that?
Hmmm. It would appear that there is a missing argument for the test
command. This means that the test command might be different on SUN than
other machines. Try comparing the man pages for SUN and Linux to see if
there are any differences in number of arguments, argument types, etc.
I would say that the error is generated from the file
src/CMD/generic/gmake.sh since it is sourced from src/CMD/gmake5.0. I
checked this file and all test commands have at least one argument. But
there are some that I'm not sure of. For example on line 60 there is the
following:
  test -d $dirname || mkdir $dirname
I'm not sure if this is standard or not since I'm only just becoming
familiar with complex sh scripting. But it would be something like this
that I would look into.
Finally I found the problem in src/CMD/generic/gmake.sh line 223:
if test -e $makefile
-> if test -f $makefile
I have changed in CVS. The test -e seems to be buggy on Solaris and
test -f does the same effect (test if file is there). On Linux it
compiles as well, please report any problems.
Additionally I have added to Makefile.in (general in grass/) to remove the
next_step file in order to start the compilation *always* from beginning
(see my other post a few days ago).
Happy again...
PS: I will try to build the Solaris NVIZ now.
subject 'unsubscribe grass5'
