On Mon, Oct 09, 2000 at 07:24:13PM +0200, grass@intevation.de wrote:
Date: Monday October 9, 2000 @ 17:24
Author: choUpdate of /grassrepository/grass/src/mapdev/v.digit
In directory intevation.de:/tmp/cvs-serv27710Modified Files:
label_mult.c
Log Message:
modified "Label/UnLabel Multiple Lines" menu to click once to perform.To label or unlabel multiple lines, two confirmations, selecting line and
do labelling/unlabelling, were needed before.Now select confirmation means also doit confirmation.
In TODO, selecting all wanted lines then confirmation was told, however
confirmation also needed when selecting each line. This can be doit
confirmation.'#define CONFIRM' is needed for doit confirmation.
Hi Huidae Cho,
sounds good! Thank for implementing this wish!
What do you think: is it feasible to implement an undo
function? As the vectors are only tagged to be deleted
it might be possible. Just another idea...
Kind regards
subject 'unsubscribe grass5'
