[GRASS5] Re: d.vect.thematic wish: handle null values
Daniel,
I hope this patch works. However, the problem might come from awk trying to
read the text file and summing a blank/null value.
Moritz, let us know if this works.
Michael
______________________________
Arizona State University
Tempe, AZ 85287-2402
USA
voice: 480-965-6262; fax: 480-965-7671
Reply-To: <daniel.calvelo@minag.gob.pe>
Date: Mon, 15 Aug 2005 13:50:02 -0500
To: Michael Barton <michael.barton@asu.edu>, <mlennert@club.worldonline.be>
Cc: Grass Developers List <grass5@grass.itc.it>
Subject: Re: [GRASS5] Re: d.vect.thematic wish: handle null values
Sorry for jumping in so late, I've been traveling.
AFAIR the problem is actually within db.select's output. Moritz, could you
apply this patch to v.univar.sh and send the result (in /tmp/db.select.out)
back to me? When I was dealing with this problem I only used the DBF driver,
which gave zeros for nulls under unspecified cirsumstances.
I can fix the script to filter out nulls, but I'm pretty sure the problem will
remain under certain configurations.
-- Daniel Calvelo Aros
---------- Original Message -----------
To: mlennert@club.worldonline.be
Cc: "daniel.calvelo@minag.gob.pe" <daniel.calvelo@minag.gob.pe>, Grass
Sent: Sat, 13 Aug 2005 17:12:29 -0700
I think that this is the place in v.univar.sh that needs to be
updated to deal with null values
# calculate statistics
echo "Calculating statistics..."
cat $TMP | awk 'BEGIN {sum = 0.0 ; sum2 = 0.0}
NR == 1{min = $1 ; max = $1}
       {sum += $1 ; sum2 += $1 * $1 ; N++}
        if ($1 > max) {max = $1}
        if ($1 < min) {min = $1}
END{
print ""
print "Number of values:",N
print "Minimum:",min
print "Maximum:",max
print "Range:",max-min
print "-----"
print "Mean:",sum/N
print "Variance:",(sum2 - sum*sum/N)/N
print "Standard deviation:",sqrt((sum2 - sum*sum/N)/N)
print "Coefficient of variation:",(sqrt((sum2 -
sum*sum/N)/N))/(sqrt(sum*sum)/N)
print "-----"
I think there needs to be the equivalent of
for $1<>""
in the beginning of this. Any awk expert know how to implement this?
Of course if v.univar were expanded to accomplish the same things as
v.univar.sh ...
Michael
On 8/12/05 2:42 AM, "Moritz Lennert" <mlennert@club.worldonline.be> wrote:
On Fri, August 12, 2005 11:27, Moritz Lennert said:
On Fri, August 12, 2005 1:49, Michael Barton said:
Thanks for the clarification Moritz. Is this in the custom breaks section?
No, this happens independently of the 'themecalc' choice.
Sorry, I lied: actually the custom breaks are the only ones that work...
All the others fail, with more or less the same error message...
Moritz
grass5 mailing list
grass5@grass.itc.it
http://grass.itc.it/mailman/listinfo/grass5
------- End of Original Message -------
