Hi again,
the G_fatal_error seems to be detected:
Roger wrote:
I've now narrowed my G_fatal_error() problem down to G_gisinit(); before
G_gisinit() is called, you can't set the handler function. After
G_gisinit(), I can reset it to use the R error() and warning() functions,
jumping back out of interface code to the R prompt safely for fatal
errors. For now I'm checking environment variables before calling
G_gisinit, but the longer-term solution is to do an interpreted
system("g.whatever") and test the value returned by exit(). If the GRASS
environment is intact and the user mapset is writable, that should be
enough. The functions in G_gisinit() get to call so many functions which
fail with G_fatal_error() that trying to guard against them all isn't
possible. Once past G_gisinit(), we're OK.
Maybe this info is useful for you...
