I would like to know the opinion of the develovers on this:
On Mon, Apr 23, 2001 at 12:05:16PM +0200, Edzer J. Pebesma wrote:
Hi Markus,
according to the programmers manual, G_fatal is defined as
int G_fatal_error(char *);
but according to gisdefs.h, it is
int G_fatal_error(char *,...);
I see that quite some code is relying on the second definition.
Should it be changed in the progr. manual, or should everyone
adopt the former?
Same thing for G_warning().
Edzer
Thanks for pointing it out,
subject 'unsubscribe grass5'
The first one will usually require the programmer to sprintf to a
buffer, which easily leads to buffer overflows. The second one could
be implemented much more safely.
Edzer
> Hi Markus,
> adopt the former?
Change the programmers manual. At some point, somebody wanted these
functions to be able to accept variable arguments, and I see no reason
(logical or software engineering wise) at this time to change them back
to a single string. Besides, changing the manual is less work than
changing several different places in the code.
Just my 2 cents worth.
Sincerely,
Jazzman (a.k.a. Justin Hickey) e-mail: jhickey@hpcc.nectec.or.th
High Performance Computing Center
National Electronics and Computer Technology Center (NECTEC)
Bangkok, Thailand
People who think they know everything are very irritating to those
of us who do. ---Anonymous
Jazz and Trek Rule!!!
I agree with Edzer, althought I still haven't seen a module
that uses the second one (but until now I only played with
raster/vector conversion modules and with s.voronoi/s.delaunay...
BTW, I nearly fixed/rewrited them, in the next few days I will send
them to Markus...). IMHO it would be better to update the manual
Andrea Aime
From: Markus Neteler <neteler@geog.uni-hannover.de>
Hi Edzer, hi all,
(cc to grass5)
> Hi Markus,
> adopt the former?
src/libes/gis/error.c defines the latter(G_fatal_error(char *msg,...),
G_warning(char *msg,...)). And its usage is more convenient than the former.
The former requires an additional buffer to store a message in most cases.
Just my thought.
Huidae Cho
> Hi Edzer, hi all,
> (cc to grass5)
> > Hi Markus,
> > adopt the former?
> > adopt the former?
A counterpoint is that, when G_fatal_error etc were changed to use
vsprintf (or similar), any code which did this:
G_fatal_error(msg);
should have been changed to:
G_fatal_error("%s", msg);
Note that gcc has the "format" attribute for printf()-like functions,
so G_fatal_error etc should probably be declared like:
This allows the compiler to detect mismatches between the format
string and the arguments.
