On Wed, Oct 18, 2000 at 11:41:37AM +0700, Justin Hickey wrote:
Hi Markus
I'm trying to decide where to put my call to G_init_env() inside
src/libes/gis/gisinit.c. One obvious place is before the call to
G_location_path() in G_gisinit(). However, what about the call
G_no_gisinit(). Should I initialize the environment there as well? Maybe
I need to check if the environment is initialized there and then
initialize it if it isn't? What do you think?
Hi Justin,
you know the G_gisinit part much better than me. I fear I have
no recommendation...
Other developers: what do you think?
subject 'unsubscribe grass5'
