[GRASS5] Re: [Gdal-dev] ERDAS/IMG driver error for NULL values
Hello Otto
Otto Dassau wrote:
Also there is no coordinate system specified. This should be:
> datum: potsdam
> towgs84: 590.5,69.5,411.6,-0.796,-0.052,-3.601,8.30
> proj: tmerc
> ellps: bessel
> a: 6377397.1550000003
> es: 0.0066743722
> f: 299.1528128000
> lat_0: 0.0000000000
> lon_0: 9.0000000000
> k_0: 1.0000000000
> x_0: 3500000.0000000000
> y_0: 0.0000000000
This looks like a deficiency in the r.out.gdal script. In GRASS 5.7 now
the co-ordinate system can be printed in WKT format using `g.proj -wf`.
I assume gdal_translate has a command-line option to specify the output
co-ordinate system and this could be easily added to the corresponding
line in the r.out.gdal script.
Just a suggestion,
Paul.
To follow up on this, I think it would mean changing the last line in
r.out.gdal from
gdal_translate -of $FORMAT $CREATEKEY $METAKEY $CELLHD $OUTPUT
to
gdal_translate -of $FORMAT -a_srs '`g.proj -wf`' $CREATEKEY $METAKEY
$CELLHD $OUTPUT
Paul
On Wed, 30 Jun 2004 13:25:39 +0100
r.out.gdal from
to
$CELLHD $OUTPUT
Hi Paul,
you are right:)
gdalinfo -mm baltrum.img
Driver: HFA/Erdas Imagine Images (.img)
Size is 17559, 8026
Coordinate System is:
PROJCS["Transverse Mercator",
    GEOGCS["unknown",
        DATUM["unknown",
            SPHEROID["bessel",6377397.155,299.1528128000033],
            TOWGS84[590.5,69.5,411.6,-0.796,-0.052,-3.601,8.3]],
        PRIMEM["Greenwich",0],
        UNIT["degree",0.0174532925199433]],
    UNIT["meters",1],
    PROJECTION["Transverse_Mercator"],
    PARAMETER["latitude_of_origin",0],
    PARAMETER["central_meridian",9],
    PARAMETER["scale_factor",1],
    PARAMETER["false_easting",3500000],
    PARAMETER["false_northing",0]]
Origin = (3391622.720000,5957462.080000)
Pixel Size = (0.32000000,-0.32000000)
Corner Coordinates:
Upper Left ( 3391622.720, 5957462.080) ( 7d21'26.28"E, 53d44'19.05"N)
Lower Left ( 3391622.720, 5954893.760) ( 7d21'29.52"E, 53d42'56.00"N)
Upper Right ( 3397241.600, 5957462.080) ( 7d26'32.75"E, 53d44'23.14"N)
Lower Right ( 3397241.600, 5954893.760) ( 7d26'35.82"E, 53d43'0.09"N)
Center ( 3394432.160, 5956177.920) ( 7d24'1.09"E, 53d43'39.60"N)
Band 1 Block=64x64 Type=UInt16, ColorInterp=Palette
    Computed Min/Max=4228.000,65535.000
  Color Table (RGB with 256 entries)
    0: 0,0,0,255
    1: 7,0,0,255
    2: 15,0,0,255
    3: 23,0,0,255
    4: 31,0,0,255
    5: 41,0,0,255
    6: 49,0,0,255
    255: 255,57,0,255
thanks for your help
    Otto
On Wed, Jun 30, 2004 at 11:14:45AM +0100, Paul Kelly wrote:
Hello Otto
Otto, are you using the original GRASS driver or the new driver
of Radim Blazek (not in CVS yet)?
This should be:
> > datum: potsdam
> > proj: tmerc
> > ellps: bessel
> > es: 0.0066743722
> > f: 299.1528128000
> > lat_0: 0.0000000000
> > lon_0: 9.0000000000
> > k_0: 1.0000000000
> > y_0: 0.0000000000
I don't think so. Because the r.out.gdal script is simply a wrapper
around gdal_translate.
In fact gdalinfo doesn't print the projection:
gdalinfo ~/grassdata/spearfish57/PERMANENT/cellhd/elevation.dem | head
Driver: GRASS/GRASS Database Rasters
Size is 633, 466
Coordinate System is `'
Origin = (590010.000000,4928000.000000)
Pixel Size = (30.00000000,-30.00000000)
Corner Coordinates:
Upper Left ( 590010.000, 4928000.000)
Lower Left ( 590010.000, 4914020.000)
Upper Right ( 609000.000, 4928000.000)
Lower Right ( 609000.000, 4914020.000)
I am using the new driver which contains the relevant code (I'm no
expert). Somewhere this info get's lost. Or should the driver make
use of the new GRASS 5.7 projection functions (such as GPJ_grass_to_wkt
in grass57/lib/proj/convert.c )?
Once solved in GDAL also r.out.gdal will write out the projection.
On Wed, 30 Jun 2004 15:02:55 +0200
> Hello Otto
I compiled GDAL with the patches from Radim for new raster support also in QGIS. I didn't use "old" libgrass. The patches were:
grassdataset.cpp3
configure.in.patch2
> This should be:
> > > datum: potsdam
> > > proj: tmerc
> > > ellps: bessel
> > > es: 0.0066743722
> > > f: 299.1528128000
> > > lat_0: 0.0000000000
> > > lon_0: 9.0000000000
> > > k_0: 1.0000000000
> > > y_0: 0.0000000000
Size is 633, 466
Corner Coordinates:
grass5 mailing list
grass5@grass.itc.it
http://grass.itc.it/mailman/listinfo/grass5
Hello Otto
grassdataset.cpp3
configure.in.patch2
Oh right I had assumed you were using old libgrass.
This should be:
datum: potsdam
proj: tmerc
ellps: bessel
es: 0.0066743722
f: 299.1528128000
lat_0: 0.0000000000
lon_0: 9.0000000000
k_0: 1.0000000000
y_0: 0.0000000000
Size is 633, 466
Corner Coordinates:
Yes I see what you mean now, that Radim's new patches call GPJ_grass_to_wkt() and the co-ordinate system should be included automatically. I'll look at it if I have some time; mightn't be for a few days though.
The change to r.out.gdal should just be considered a temporary workaround then.
Also I noticed that the datum name didn't get printed in Otto's example (Deutsches_Haupt... for potsdam) either. That looks like a bug which I will have a look at.
Paul
On Wednesday 30 June 2004 17:11, Paul Kelly wrote:
> grassdataset.cpp3
> configure.in.patch2
days though.
GPJ_grass_to_wkt is disabled in grassdataset.cpp3 because of circular references,
projection is not set.
Radim
also in QGIS.
I'm just wondering if the brand new 1.2.1 version of GDAL includes
what's needed for displaying GRASS rasters in QGIS? What about PostGIS
support?
see http://article.gmane.org/gmane.comp.gis.grass.devel/3999
Hamish
> also in QGIS.
support?
The patches for 5.7 are not yet in GDAL CVS, it is also possible
to use libgrass.
Radim
