John Gillette wrote:
Hi Greg,
I saw your post and had a couple of questions.
Do dglib and dgtable go "on top" of the vector
library? That is, are they independent of how the
data for the vectors is currently stored?I have started reading books on computational geometry
and have been thinking about some problems that
Grass currently can't do such as the union of polygons
(and ultimately whole maps). I have been thinking
about how grass stores topology. I have been studying
the doubly connected edge list (DCEL)[1]. However,
it occurs to me that this could be implemented on
top of and independently of how the data is currently stored.
I think it makes a lot of sense to have one copy of the vertices, that
other structures can index. I chose path arrays as the structure that
stores the vertices. There may be better choices, but I like the idea
of making adjacent vertices in a path also adjacent in memory ...
hopefully exploiting cache designs for common tasks such as drawing
paths. Then I have other structures (e.g., R-tree) that index into that
storage.
I am also interested in your "conflate" operation.
How is that going?
Unfortunately I haven't found any literature describing how others have
implemented/attempted map conflation. I'm approaching it as an exercise
in path correlation: the paths, in different maps, that correlate the
most can share attributes (e.g., labels). Too soon to tell if this
approach is too simplified.
Greg
[1] Computational Geometry:Algorithms and Applications 2nd
edition, de Berg, et al, Springer Verlag, 2000
