[GRASS5] Re: [GRASS-COMMIT-CVS] CVS update: configure
On Tue, Oct 10, 2000 at 12:17:19PM +0200, grass@intevation.de wrote:
Date: Tuesday October 10, 2000 @ 10:17
Author: cho
Update of /grassrepository/grass
In directory intevation.de:/tmp/cvs-serv2707
Modified Files:
  configure
Log Message:
modified to find libpq-fe.h automatically without --with-postgresql option.
If not found, postgresql support doesn't set.
You can also use --without-postgresql/--with-postgresql option.
Due to this update we are able to modify the "NVIZ" configure
again. I propose that
- the local configure of NVIZ will be kept like this, but
- the Gmakefile will be generated automatically with sensivity to
   PostgreSQL support
Results:
- the user can easily override the standard settings by running the
   local configure
- a standard Gmakefile will be generated based on variables tested
   by global configure
- if the minimum requirements are not fulfilled, the Gmakefile should
   not be generated.
I feel this is subject to change in 5.1devel later. But we should have
a rather stable version for the forthcoming 5.0stable.
What do you think?
subject 'unsubscribe grass5'
   PostgreSQL support
Results:
   local configure
   by global configure
   not be generated.
What do you think?
The only thing I would add would be that we make sure the NVIZ configure
script is eliminated for 5.1. The global configure script should be the
only one needed.
Sincerely,
Jazzman (a.k.a. Justin Hickey) e-mail: jhickey@hpcc.nectec.or.th
High Performance Computing Center
National Electronics and Computer Technology Center (NECTEC)
Bangkok, Thailand
People who think they know everything are very irritating to those
of us who do. ---Anonymous
Jazz and Trek Rule!!!
