[GRASS5] Re: [GRASS-COMMIT-CVS] CVS update: grass/src/libes/raster
Hi Eric,
On Thu, Nov 30, 2000 at 04:47:06AM +0100, grass@intevation.de wrote:
Date: Thursday November 30, 2000 @ 3:47
Author: eric
Update of /grassrepository/grass/src/libes/raster
In directory intevation.de:/tmp/cvs-serv4834
Modified Files:
  io.c
Log Message:
Fix d.mon -L bug I think (this'll need to be propagated to io.c in ipc.new)
congrats! It is fixed for Linux/fifos.
Regards
subject 'unsubscribe grass5'
Hi Eric, Hi Markus,
very nice, it works now. Now you can even close monitors by "killing"
them.
I have the fix for the typecast ready and i have nearly ready a code
reorganization that allows to switch between fifo and ipc messages by
compiler switch (-DIPC or -DFIFO).
Just to announce this, so that we do not get under our feet again. I
hope that it can wait until Saturday morning, as i will check it in
then.
I'll have a look at this weird CELL driver problem too.
There is no need to propagate the change to the ipc-new/io.c, as it
works with ipc msgs. because the system with testing by opening a fifo
is not used there.
cu,
Andreas
Markus Neteler wrote:
Hi Eric,
> Author: eric
> Modified Files:
> io.c
> Log Message:
Regards
Andreas Lange, 65187 Wiesbaden, Germany, Tel. +49 611 807850
Andreas.Lange@Rhein-Main.de - A.C.Lange@GMX.net
On Fri, Dec 01, 2000 at 01:06:02AM +0100, Andreas Lange wrote:
Hi Eric, Hi Markus,
them.
Hi Andreas, hi Eric,
this would be great and helpful! The behaviour changed but on KDE desktop
environment the monitor does *not* close when hitting the close button
on monitor window (just nothing happens). However, after invoking another
d.* module, the monitor closes and can be restarted without problems. So
generally it seems to be o.k., but the close "button" is locked.
Using fvwm2 or whatever I expect that the monitor will close immediately. I
can try that at home. Do you have a hint to make monitors on KDE behave like
this?
then.
O.k., no problem. Take yout time of course.
Thanks as well!
Regards
