[GRASS5] Re: [GRASS-COMMIT-CVS] CVS update: grass/src/raster/r.binfer
Hi David,
On Wed, Nov 15, 2000 at 05:50:31PM +0100, grass@intevation.de wrote:
Date: Wednesday November 15, 2000 @ 16:50
Author: david
Update of /grassrepository/grass/src/raster/r.binfer
In directory intevation.de:/tmp/cvs-serv18425
Modified Files:
  binfer.l
Log Message:
Changed to elliminate `dangerous trailing context' warning: caused parse
failure (in binfer.y) on linux-i386 at least
on SUN/Solaris and i686-pc-linux-gnu is compiles o.k. without
any problems.
On cray I get:
/home/t3e/fsn/nhdc/nhdcmark/grass/src/raster/r.binfer
  make -f OBJ.alpha-cray-unicosmk2.0.4.X/make.rules
        rm -f lex.c gram.c
        yacc binfer.y
        rm -f gram.c
        mv y.tab.c gram.c
        cc -g -I/home/t3e/fsn/nhdc/nhdcmark/grass/src/include -c gram.c
-o OBJ.alpha-cray-unicosmk2.0.4.X/gram.o
        lex binfer.l
"binfer.l":line 13: Error: Missing translation value
Make: "lex binfer.l": Error code 1
But it is lex there, not flex:
     lex - Generates programs for simple lexical tasks
   STANDARDS
     POSIX, XPG4
well, let's ignore CRAY...
Thanks for updating
subject 'unsubscribe grass5'
Markus Neteler wrote:
Hi David,
> Author: david
> Modified Files:
> binfer.l
> Log Message:
any problems.
On cray I get:
        rm -f lex.c gram.c
        yacc binfer.y
        rm -f gram.c
        mv y.tab.c gram.c
        lex binfer.l
   STANDARDS
     POSIX, XPG4
Thanks for updating
Hi Markus
Do you know exactly what lex Cray uses? The problem seems to be the
%option statement. So perhaps we could get round that by putting in
conditional code, as Cray presumably doesn't need the lex-compat
statement. Do you [anyone] know off-hand the definition code for Cray?
David
On Wed, Nov 15, 2000 at 08:09:40PM +0000, David D Gray wrote:
> > Author: david
> > Modified Files:
> > binfer.l
> > Log Message:
> On cray I get:
> rm -f lex.c gram.c
> yacc binfer.y
> rm -f gram.c
> mv y.tab.c gram.c
> lex binfer.l
> STANDARDS
> POSIX, XPG4
> Thanks for updating
> Markus
Hi Markus
Hi David,
how can I find out?
man lex
LEX(1) UNICOS/mk 2.0.4 Last changed: 2-24-98
NAME
SYNOPSIS
     lex [-t] [-r] [-n] [files]
     lex [-t] [-r] [-v] [files]
     Obsolescent version; may not be supported in future releases:
     lex -c [-t] [-r] [-n] [files]
     lex -c [-t] [-r] [-v] [files]
IMPLEMENTATION
     CRAY T3E systems
STANDARDS
     POSIX, XPG4
     AT&T extensions (-r option)
SEE ALSO
     yacc(1)
     lex & yacc, Doug Brown and Tony Mason, O'Reilly & Associates, Inc.,
     1992.
     The UNIX Programming Environment, Brian W. Kernighan and Rob Pike,
     Prentice-Hall, Inc., 1984.
     UNICOS/mk User Commands Reference Manual, publication SR-2611, for the
     printed version of this man page.
Is there anything else I could try?
> > > Author: david
> > > Modified Files:
> > > binfer.l
> > > Log Message:
> > On cray I get:
> > rm -f lex.c gram.c
> > yacc binfer.y
> > rm -f gram.c
> > mv y.tab.c gram.c
> > lex binfer.l
> > STANDARDS
> > POSIX, XPG4
> > Thanks for updating
> > Markus
> Hi Markus
Hi David,
how can I find out?
man lex
NAME
SYNOPSIS
IMPLEMENTATION
     CRAY T3E systems
STANDARDS
     POSIX, XPG4
SEE ALSO
     yacc(1)
     1992.
This is my reference. The above suggests that the cray lex is probably a
posix lex, as described here.
I think the following is the solution:
Remove `%option lex-compat' from the scanner file. This is a flex
feature and so other lex's will not recognise it. Also comment out
references to `yylineno' in stable code. A file is included with a list
of the locations of yylineno locations so that anyone hacking on the
module can restore them if required [?]. During this development and
testing the `LEX= flex -l' option would be available
in the Gmakefile, otherwise commented out.
The best way would still be to use conditional code with an environment
variable like LEX_IS_FLEX, when set it would allow the LEX variable to
be over-ridden in the local Gmakefile depending on whether the lex on
the system is _really_ flex. But - how do you determine that?
I haven't committed these changes yet. I wanted to wait if anyone had
any objections.
David
