[GRASS5] Re: [GRASS-CVS] CVS update: grass/src/display/devices/CELL
Glynn,
the recent changes to XDRIVER introduced a bug:
Try:
export GRASS_HEIGHT=100
d.mon x0
using default visual which is TrueColor
ncolors: 65536
Graphics driver [x0] started
d.mon stop=x0
d.mon x0
X Error of failed request: BadValue (integer parameter out of range for
operation)
  Major opcode of failed request: 1 (X_CreateWindow)
  Value in failed request: 0x0
  Serial number of failed request: 8
  Current serial number in output stream: 20
No socket to connect to for monitor <x0>.
Problem selecting x0. Will try once more
export GRASS_HEIGHT=33
d.mon x0
ncolors: 65536
Please pre-define the variable if unset (will also affect GRASS_WIDTH,
unchecked).
Then a question: Now PNGDriver and Xdriver use the same size variables
GRASS_HEIGHT and GRASS_WIDTH (or not?).
I am not sure if that is a good idea (less convenient than before).
Usually the monitor will be smaller than file output to PNG.
On Sat, Feb 16, 2002 at 08:13:02AM +0100, grass@intevation.de wrote:
Date: Saturday February 16, 2002 @ 7:13
Author: glynn
Update of /grassrepository/grass/src/display/devices/CELL
In directory doto:/tmp/cvs-serv21664/src/display/devices/CELL
Modified Files:
      Tag: releasebranch_11_april_2001_5_0_0
  cell.h Graph_Set.c
Log Message:
General display driver tidying
Move screen_{left,right,top,bottom} and initialisation thereof to lib/main.c
XDRIVER now uses GRASS_{WIDTH,HEIGHT} instead of XDRIVER_{WIDTH,HEIGHT}
Move DEF_{WIDTH,HEIGHT} to lib/driver.h
XDRIVER now defaults to 640x480
Move NCOLORS to lib/main.c
Move declarations for screen_* and NCOLORS to lib/driver.h
Document various env vars:
GRASS_BACKGROUNDCOLOR, GRASS_TRANSPARENT, XDRIVER_WINDOW
Eliminate preprocessor abuse
Remove program-specified position from XDRIVER; let WM place window
Remove gratuitous references to BUFSIZ
Remove redundant SC_{WID,HITE} variables from XDRIVER
Remove leading underscores from _text_* variables
Move definitions of text_*, cur_[xy] to lib/main.c
Move declarations of text_*, cur_[xy] to lib/driver.h
Add d.resize script
grass-commit mailing list
grass-commit@grass.itc.it
http://grass.itc.it/mailman/listinfo/grass-commit
Try:
d.mon x0
ncolors: 65536
d.mon stop=x0
d.mon x0
operation)
[snip]
unchecked).
OK, done.
Yes; all monitors now use these variables. The intention was to make
it easier for programs which manage monitors, so that they don't need
a table of which monitor uses which variables.
If you want per-monitor-type variables, it would be better to
generalise the mechanism using the driver name, e.g. with something
like GRASS_WIDTH_XDRIVER, GRASS_WIDTH_PNG, GRASS_WIDTH_CELL etc rather
than having a special case for one of the drivers.
[snip]
[snip]
> unchecked).
OK, done.
Thanks, working now.
Well, what's preferred? Individual size variables for each driver or
overall variables? Opinions?
> [snip]
[snip]
> > unchecked).
> OK, done.
one set of variables (GRASS_WIDTH, GRASS_HEIGHT) for all
monitors/drivers. IMHO one can change the variables after opening the
driver, so that new started monitors inherit the new values with their
environment.
Just my opinion.
Andreas
Andreas Lange, 65187 Wiesbaden, Germany, Tel. +49 611 807850
url: http://mitglied.tripod.de/AndreasLange
mail: Andreas.Lange_at_Rhein-Main.de - A.C.Lange_at_GMX.net
