On Fri, Apr 18, 2003 at 03:16:08AM +0200, grass@intevation.de wrote:
Author: hamish
Update of /grassrepository/grass/src/general/g.gisenv
In directory doto:/tmp/cvs-serv17054Modified Files:
main.c
Log Message:
allow program to run even with a corrupted mapset (so you can fix it) [Bug 1797]Index: main.c
RCS file: /grassrepository/grass/src/general/g.gisenv/main.c,v
retrieving revision 1.9
retrieving revision 1.10
diff -u -d -r1.9 -r1.10
--- main.c 12 Apr 2003 06:27:11 -0000 1.9
+++ main.c 18 Apr 2003 01:16:06 -0000 1.10
@@ -12,7 +12,8 @@
struct Option *get, *set;
struct GModule *module;
- G_gisinit (argv[0]);
+ G_set_program_name(argv[0]);
+ G_no_gisinit();module = G_define_module();
module->description =
Is this fix also desired for 5.1? If yes, someone (me?) should
merge it into.
