On Sat, Mar 01, 2003 at 05:21:01AM +0100, grass@intevation.de wrote:
Author: hamish
Update of /grassrepository/grass/src/tcltkgrass/module
In directory doto:/tmp/cvs-serv28849
Modified Files:
s.in.ascii
Log Message:
Added d= option for number of dimensions. [bug 1564]
I didn't add the missing date= option as I don't know the correct usage.
Hamish,
it works the same as for r.timestamp. In fact a related note should
be added to
s.in.ascii.html and
s.in.dbf.html
> Modified Files:
> s.in.ascii
> Log Message:
> usage.
be added to
s.in.ascii.html and
s.in.dbf.html
Right, that makes more sense then. But before I fix them up, some questions:
The [r|v].timestamp html pages seem to need updating too, as the example
for date range:
v.timestamp map=soils date='15 sep 1987,20 feb 1988'
doesn't work. What does seem to work is:
v.timestamp map=soils date='15 sep 1987/20 feb 1988'
Is that correct?
What's more, [r|v].timestamp will write a bad timestamp string to the file
without question; you get the error when you try to display the timestamp:
"WARNING: Invalid timestamp file for raster map ..."
I assume this is wrong; the following patch makes it right..
[This is against r.timestamp, but v.timestamp is almost the same, and
s.in.ascii & s.in.dbf's G_scan_timestamp() calls should probably get
the same test as well.]
Should this be applied?
Is G_fatal_error() more appropriate than exit(1)?
