[GRASS5] Re: [GRASS-CVS] markus: grass Makefile.in,1.94,1.95
Hi Markus,
seems to me this is excessive to create "locale"
directory if it was missing (actually, it would always
be missing). tar xBf would copy the entire "locale"
directory to $INST_DIR in case it happened to occur in
$GISBASE after gmake5 works in src/locale. This was
tested more then once.
--alex
--- grass@intevation.de wrote:
Author: markus
Update of /grassrepository/grass
In directory doto:/tmp/cvs-serv2512
Modified Files:
  Makefile.in
Log Message:
bugfix for creating locale directory in INST_DIR -
was missing
Index: Makefile.in
RCS file: /grassrepository/grass/Makefile.in,v
retrieving revision 1.94
retrieving revision 1.95
diff -u -d -r1.94 -r1.95
--- Makefile.in 10 May 2002 12:46:33 -0000 1.94
+++ Makefile.in 15 May 2002 08:30:55 -0000 1.95
@@ -184,6 +184,7 @@
   ${SHELL} -c "cd ${GISBASE} ; tar cBf - scripts |
(cd ${INST_DIR} ; tar xBf - ) 2>/dev/null ; true"
   ${SHELL} -c "cd ${GISBASE} ; tar cBf - tcltkgrass
   ${SHELL} -c "cd ${GISBASE} ; tar cBf - txt | (cd
+ test -d ${GISBASE}/locale && test -d
${INST_DIR}/locale || ${MAKE_DIR_CMD}
${INST_DIR}/locale
   test -d ${GISBASE}/locale && ${SHELL} -c "cd
${GISBASE} ; tar cBf - locale | (cd ${INST_DIR} ;
   @ # The man, include, and lib could go to
${PREFIX}/ BUT if this is
   @ # done, then the corresponding uninstall
instructions must delete
grass-commit mailing list
grass-commit@grass.itc.it
http://grass.itc.it/mailman/listinfo/grass-commit
__________________________________________________
Do You Yahoo!?
LAUNCH - Your Yahoo! Music Experience
http://launch.yahoo.com
On Wed, May 15, 2002 at 03:16:45AM -0700, Alex Shevlakov wrote:
Hi Markus,
Hi Alex,
here the tar command crashed... maybe this function is not
fully portable?
test -d /usr/local/src/grass5.0.0pre4/dist.i686-pc-linux-gnu/locale &&
/bin/sh -c "cd /usr/local/src/grass5.0.0pre4/dist.i686-pc-linux-gnu ;
tar cBf - locale | (cd /usr/local/grass5 ; tar xBf - ) 2>/dev/null ;
true"
make[1]: *** [real-install] Error 1
make[1]: Leaving directory /usr/local/src/grass5.0.0pre4'
make: *** [install] Error 2
That's why I was adding it.
--alex
> Author: markus
> Modified Files:
> Makefile.in
> Log Message:
> was missing
> Index: Makefile.in
> @@ -184,6 +184,7 @@
> ${INST_DIR}/locale
Do You Yahoo!?
grass5 mailing list
grass5@grass.itc.it
http://grass.itc.it/mailman/listinfo/grass5
Markus Neteler
ITC-irst, Istituto per la Ricerca Scientifica e Tecnologica
     Project on Predictive Models for the Environment
Via Sommarive, 18 - 38050 Povo (Trento), Italia
tel +39 0461 314 -520 (fax -591) http://mpa.itc.it
