does anyone know how the malloc.h should be done below?
AFAIK, GRASS is free of malloc.h except for below code.
-----Original Message-----
From: grass-commit-admin@grass.itc.it on behalf of grass@intevation.de
Sent: Sun 2006-01-22 05:06
To: grass-commit@grass.itc.it
Subject: [GRASS-CVS] scott: grass6/raster/simwe/r.sim.water main.c,1.9,1.10
Author: scott
Update of /grassrepository/grass6/raster/simwe/r.sim.water
In directory doto:/tmp/cvs-serv11961
Modified Files:
main.c
Log Message:
Added check for Apple compiler in check for malloc.h - may not be appropriate check?
Index: main.c
RCS file: /grassrepository/grass6/raster/simwe/r.sim.water/main.c,v
retrieving revision 1.9
retrieving revision 1.10
diff -u -d -r1.9 -r1.10
--- main.c 19 Jan 2006 12:57:28 -0000 1.9
+++ main.c 22 Jan 2006 04:06:06 -0000 1.10
@@ -42,8 +42,11 @@
#include <stdio.h>
#include <stdlib.h>
#include <math.h>
-#if !(defined(__FreeBSD__) || defined(__NetBSD__) || defined(__OpenBSD__))
+#if !(defined(__FreeBSD__) || defined(__NetBSD__) || defined(__OpenBSD__) || defined(__APPLE_CC__))
/* <malloc.h> has been replaced by <stdlib.h> in *BSD. */
+/* and Mac OS X is based on BSD, but apparently doesn't define those symbols */
+/* At the moment, if APPLE_CC is defined, we're using Apple's compilers - */
+/* but that probably isn't the best test. What is a better way ? */
#include <malloc.h>
#endif
grass-commit mailing list
http://grass.itc.it/mailman/listinfo/grass-commit
