Based on the additions from Malcolm, and some of my own,
I have updated the compile_grass_with_wincygnus.txt in the
documents directory. Please update your file.
I did not edit the html, Malcolm, let me know if you want
me to do it.
I uploaded a file grass5-20010206.zip to the incoming directory.
This includes a StartGrass script in the /usr/local/grass5
directory. I think I added enough for someone to run
it OK. It is a relative root so someone can unzip it to
their D: drive if necessary.
Markus, please update the binary and the text file in
http://www.geog.uni-hannover.de/grass/grass5/binary/windows_cygnus/
John Huddleston
----- Original Message -----
To: "John Huddleston" <jhudd@lamar.colostate.edu>
Cc: "Markus Neteler" <neteler@geog.uni-hannover.de>
Sent: Monday, January 29, 2001 5:13 AM
Subject: Re: Grass on CYGWIN/WIN32> John,
> I have attached a revised Compile_grass_with_cygwin.html (and .txt)
file. I
> cleaned up some notes about the compilation process that didn't belong
there.
> Also, I see that 'which' is still used in README.ipc. I had a copy of
which in my
> path, so I didn't find that out until yesterday. I can send him a
change for that
> to make it more cygwin friendly later today.
> Huidae has revised some of the IPC related files (late last night in my
time zone),
> but I haven't had a chance to test these. I think, judging from the
changes he
> made, that he is automating the create_buffers.sh process more. I will
try to look
> at these later today.
> Malcolm
subject 'unsubscribe grass5'
