On Fri, Nov 10, 2000 at 06:10:44PM -0700, John Huddleston wrote:
Markus,
Regarding the pruning, removed files, etc., I seem to remember
an email from Bernhard this past summer about how you keep
two CVS repositories. If this is the case, it would be possible
for me to do the update and miss some of the "pruning"
operations How do you manage to keep two CVS repositories
in sync? Yes, I did do the appropriate options on the cvs
command.
up to now we have one CVS repository. Later we will open the
5.1 repository for the "new GRASS". I guess the 5.0 tree
will get somewhat sleepy then.
[new Makefile system]
> But you could get it from
> Eric Mitchell <emitchell@altaira.com>
> in a package. Maybe you can test it and discuss improvements with
> Eric to have them already in when 5.1 is started.
I would be happy to test out the makefile system. Years ago
I wrote a Makefile builder for our Unix development teams.
It included a slick dependency checker for the source files.
If we included a "utility" section in grass, I would be happy
to add that to our system.
This sounds very interesting. Perhaps the "makefile professionals"
here could discuss this idea?
Kind regards
subject 'unsubscribe grass5'
Sorry if I sounded irritated about the build system changing
and lashed out at Linux. That was not the intent. Grass is
a large system and it takes quite a while to build unattended.
If a failure occurs then it takes more of my time to figure
out what failed. Since my time is short this hand editing
of Gmakefiles is a bother. Building Grass5 for windows
used to be a clean process; now it takes much more time.
John Huddleston
----- Original Message -----
From: "Markus Neteler" <neteler@geog.uni-hannover.de>
To: "John Huddleston" <jhudd@lamar.colostate.edu>; "grass5 developers list" <grass5@geog.uni-hannover.de>
Sent: Saturday, November 11, 2000 4:44 AM
Subject: [GRASS5] Re: grass windows build
Hi John,
[cc to grass5]
> Markus,
> command.
Kind regards
On Sat, Nov 11, 2000 at 07:21:59AM -0700, John Huddleston wrote:
Hi Markus,
this is somewhat surprising. I was expecting the Gmakefiles
in the best conditions than ever! Please let me know where to
fix things.
