[GRASS5] Re: grass5 digest, Vol 1 #435 - 2 msgs
hello:
i think that you want:
  TCLTKGRASSBASE: /usr/local/grass5/bin/tcltkgrass
in your ~/.grassrc5 instead of:
  TCLTKGRASSBASE: /sw/grass5/tcltkgrass
as i installed GRASS in my Fink directory.
Take care,
Andy
On Wednesday, August 7, 2002, at 05:01 AM, grass5-request@grass.itc.it wrote:
Message: 1
Date: Wed, 7 Aug 2002 10:23:33 +0200
To: grass5 developers list <grass5@grass.itc.it>
Subject: [GRASS5] [eyreka@mac.com: more onTclTkGRASS troubles]
attached a lady with tcltkgrass problems on MacOSX.
Does anyone have a suggestion for her?
Hello again,
Still having problems with TlcTkGRASS. I referred to discussions
suggested by Markus and particularly to bit about adding
'TCLTKGRASSBASE: /sw/grass5/tcltkgrass' to .grassrc5 but also noted that
what I am interpreting as the TclTkGRASS script, tcltkgras.tcl (typed in
red on attached rtf file), is missing lines shown on
'http://grass.itc.it/pipermail/grass5/2002-June/003464.html’ and
repeated by me (also in red print) at the end of attached file. Could
this be source of my problem?
From original message:
Hello,
I just got around to installing my update of GRASS 5.0.0pre4 from
OpenOSX and find I've a problem with the TlcTkGRASS gui. I don't
currently use the GUI but will want to do so and would appreciate any
help getting it going again.
When I give the command tlctkgrass& as below
GRASS 5.0.0pre4 > tcltkgrass&
the main menu bar briefly appears and then I get the message:
