[GRASS5] Re: [GRASSLIST:10372] QGIS/GRASS for Windows 060217
On 2/21/06, "Peter Löwe" <peter.loewe@gmx.de> wrote:
The problem can be reproduced:
OS: Windows XP Professional Service Pack 2, no admin privileges
1) Download & unpacking of qgis-0.7.9-win32-060217.zip (34MB)
2) Download of spearfish_grass60data.tar.gz
3) Unpacking of the spearfish location by doubleclicking/"WinZip" using the
defaults.
Here is the problem. By default, WinZip is using 'TAR file smart
CR/LF conversion'.
If you go to Options->Configuration->Miscelaneous and disable the
TAR CR/LF conversion it should work.
Obviously this is not convenient, I think that we should probably prepare
demo data packages also in zip format.
Radim
4) Opening vectors from the spearfish location works fine.
5) Opening raster layers fails, same error message as discussed below.
>> > However, when trying to open any grass raster, I get the following
>error:
>> > "C:/..../locations//spearfish60/PERMANENT/cellhd/elevation.10m is not
>a
>> > supported raster data source".
>> > Is raster processing still unstable or are maybe specific read/write
>> > privileges to be set ?
>Today I tested GRASS rasters with qgis-0.7.9-win32-060217
>and Spearfish and it works for me.
>Do you have other versions of GDAL on your system?
>It should not be problem because Windows should first search for
>DLL in the directory where application is located.
>Anybody other had success/problems with GRASS rasters?
Dr. Peter Löwe
Diplom-Geograph
<loewe@geomancers.net>
10 GB Mailbox, 100 FreeSMS/Monat http://www.gmx.net/de/go/topmail
+++ GMX - die erste Adresse für Mail, Message, More +++
> defaults.
CR/LF conversion'.
Done:
http://grass.itc.it/download/data6.php
-> SPEARFISH 6.0 data set
      -> tar.gz
      -> zip
Enjoy
Markus Neteler <neteler itc it> http://mpa.itc.it
ITC-irst - Centro per la Ricerca Scientifica e Tecnologica
MPBA - Predictive Models for Biol. & Environ. Data Analysis
Via Sommarive, 18 - 38050 Povo (Trento), Italy
Is anyone working with command line GRASS for windows?
I'd like to know if the new GIS Manager that uses TclTk canvases instead of
x displays works with this windows-native version of GRASS and
windows-native TclTk.
Michael
Arizona State University
Tempe, AZ 85287-2402
phone: 480-965-6213
fax: 480-965-7671
Date: Tue, 21 Feb 2006 14:33:34 +0100
To: Peter Löwe <peter.loewe@gmx.de>
Cc: <GRASSLIST@baylor.edu>, <qgis-user@lists.sourceforge.net>, grass
developers list <grass5@grass.itc.it>
Subject: [GRASS5] Re: [GRASSLIST:10372] QGIS/GRASS for Windows 060217
defaults.
CR/LF conversion'.
Radim
error:
a
Dr. Peter Löwe
Diplom-Geograph
10 GB Mailbox, 100 FreeSMS/Monat GMX TopMail - E-Mail maximal mit dem Alleskönner-Postfach
I found another problem, map canvas is not redrawn when
when raster is loaded (works for vectors). You need to
zoom/pan/full-extent or resize/hide-show qgis window.
I'll try to fix that but the qgis canvas will be replaced by Martin's code
soon anyway.
Radim
> defaults.
CR/LF conversion'.
Radim
> >error:
> >a
> Dr. Peter Löwe
> Diplom-Geograph
