"F.Tusell" wrote:> >
Thank you very much for your reply. I have looked at the directory
named diglib in src/libes/vect32_64/ but diglib64 is not there,
only diglib. I have made a link:ln -s src/libes/vect32_64/diglib src/libes/vect32/diglib64
with the hope that the compiler would find it.
And it does, but other files are missing. The compiler complains
about missing "includes", and in fact in the directorysrc/libes/vect32_64/diglib
a command: grep "include" *.c yields:
allocation.c:#include "digit.h"
allocation.c:#include <unistd.h>
allocation.c:#include <stdlib.h>
area.c:#include "digit.h"
area.c:#include <stdlib.h>
attribute.c:#include "digit.h"
attribute.c:#include "dig_atts.h"
[output chopped]while ls -l *.h only returns:
-rw-r--r-- 1 etptupaf etptupaf 26 Dec 29 1999 debugf.h
-rw-r--r-- 1 etptupaf etptupaf 337 Feb 3 2000 digit.h
-rw-r--r-- 1 etptupaf etptupaf 231 Nov 9 18:33 portable.hAre you certain the diglib in vect32_64 is what the compiler searches
as diglib64? If so, can I take the missing files from the diglib in
vect32?Thank you again.
ft.
I am not sure (I don't have 64bit machine). I think that
libes/vect32/diglib64 was removed "Thu Jul 13 05:52:04 2000" with message
"Bill Hughes: removed, will be continued in ../vect32_64/" but
it seems that vect32_64/ is not maitained now (all files 10 month old).
Vector includes were restructured (in summer?, everything now in Vect.h) and changes
were done only in vect32/ not in vec32_64/.
I am also interested because we have to merge vect32/ and vect32_64/
in vectlib in grass51.
Somebody knows more about?
Radim
subject 'unsubscribe grass5'
