[GRASS5] Re: [GRASSLIST:1116] compiling postgres modules
Hi Moritz,
On Tue, Nov 14, 2000 at 10:33:24AM +0100, mlennert@club.worldonline.be wrote:
> I have the feeling there is a problem with my cvs. I've update through cvs
> update -dP, but the Makefile and the configure file had not been updated. What
> am I doing wrong ?
The Makefile won't be updated as it is generated from Makefile.in.
The configure might not be updated, if it is already up-to-date.
Sorry, I wasn't clear enough: I wanted to say Makefile.in.
And no, neither one of the two had been updated yesterday when I did a 'cvs
update -dP' in my grass cvs directory. Now I can't check anymore, since I've
erased everything and redownloaded it via 'cvs -z3 co grass' (I did need grass
for work...). Now the files are the correct ones. I guess we'll just have to
wait until the next updates to check wether the problem reoccurs.
So, look for the Makefile.in timestamp.
Hope this helps
subject 'unsubscribe grass5'
On Tue, Nov 14, 2000 at 02:24:23PM +0100, mlennert@club.worldonline.be wrote:
> Hi Moritz,
> > am I doing wrong ?
If you are interested, you can track the ongoing CVS updated "realtime":
http://www.geog.uni-hannover.de/grass/grasscvscommit.html
:slight_smile:
