[GRASS5] Re: [GRASSLIST:1122] Re: monitor management unstable
On Mon, Nov 13, 2000 at 06:10:46PM +0100, mlennert@club.worldonline.be wrote:
> After compiling the CVS tree, the monitor management seems unstable on my
> machine. TclTkGrass has actually crashed a few times, for example when I try
> to stop a monitor. The connection to the monitors seem to break quite often,
> and so I get "x0 is used by another user". I actually think it might be a
> problem in TclTkGrass since I haven't had this problem from the console. (I
> was using d.what.vect when the problem appeared, but I've also had it after a
> simple d.vect, d.rast suite).
Hi Moritz,
this is surprising as the monitor management is unchanged for month.
We have recently included a preliminary IPC-support, but this is
not used on default. So I guess it is a local problem (maybe new
Xfree version or new windows manager?).
Please: for discussions on CVS related stuff, please use the
developer list (not to bother the "stable users").
Thanks
Ok, here I am on the developer list. Sorry for hving bothered the main list,
but I did not consider myself a developer :wink:
I have recently switched to X11R6.4 (4.0.1-3), so that might be the problem.
Moritz
subject 'unsubscribe grass5'
