[GRASS5] Re: [GRASSLIST:1246] a problem in NVIZ
I will appreciate if anyone explains reason of this problem concerning
NVIZ.
I'm working on it..........
(grass5.0 runs in slackware9.0)
[that's the second hit for this bug with Slackware 9.0, for anyone
keeping score. What gcc, glibc, tcl versions is that please?]
[GRASS:~ > nviz ...]
Nv_(panels)
toplevel made
child killed: segmentation violation
hmmmm.. that's in a different place to where it was breaking for me.
(Debian/Testing)
Is it a floating point or integer based map?
If it is an integer based map, try converting it to a FP with r.mapcalc,
  (r.mapcalc fpmap=origmap*1.0)
and see if that works. (doubtful)
Try compiling with -DDEBUG_MSG and see if that fixes it.
   (CFLAGS=-DDEBUG_MSG ./configure ...)
[that worked here, I have no idea why]
Try compiling with gcc ~2.95 if you can & see if that fixes it.
[that works here]
Which version of Tcl are you using? Does using 8.3 help?
please let me know if any of this works, or doesn't.
I've currently got my integer-map bug tracked down to this line on
src/libes/ogsf/GS2.c: (line 1445)
   filename = G_fully_qualified_name(filename, mapset);
Next is to follow G_fully_qualified_name() in src/libes/gis/nme_in_mps.c.
Hopefully this leads somewhere.
You're getting past that into etc/nviz2.2/scripts/nviz2.2_script though.
tcl8.4?? Maybe try adding -lpthreads to the end of XTRA_LDFLAGS in
src.contrib/GMSL/NVIZ2.2/src/Gmakefile
and see what that does?
also of note, we have both:
/src.contrib/GMSL/NVIZ2.2/scripts/nviz2.2_script
and
/src.contrib/GMSL/NVIZ2.2/nviz2.2/scripts/nviz2.2
Which are almost the same thing. The first one is the real one.
oh, what fun,
Hamish
/usr/local/grass5/etc/nviz2.2/scripts
Nv_(panels)
toplevel made
    while executing
"exec /usr/local/grass5/etc/nviz2.2/NVWISH2.2 -f
/usr/local/grass5/etc/nviz2.2/scripts/nviz2.2_script
-name NVIZ >&@stdout"
    ("eval" body line 1)
    invoked from within
"eval exec $env(GISBASE)/etc/nviz2.2/NVWISH2.2 -f
$env(GISBASE)/etc/nviz2.2/scripts/nviz2.2_script -name
NVIZ >&@stdout"
    invoked from within
"if {$argv == ""} {
#no arguments
NVIZ >&@stdo..."
    (file "/usr/local/grass5/bin/nviz" line 16)
It leads to:
  char *
  G_fully_qualified_name (name, mapset)
      char *name;
      char *mapset;
      char fullname[1024];
      char *G_store();
      if(strchr(name, '@'))
        sprintf (fullname, "%s", name);
      else
        sprintf (fullname, "%s@%s", name, mapset);
      return G_store(fullname);
My guess is that the heap has previously been corrupted, causing a
subsequent call to malloc() (in G_store()) to segfault. If so, then
debugging from the point that SIGSEGV is received won't help any; you
would need to either use memory debugging tools such as Electric Fence
or try to manually discover the source of the overrun.
Hamish wrote:
I am using binary version of grass (5.0).
5.0.3 will be out soon, you might just wait for that & then for a new
binary to be posted a few days later.
( could you possibly tell me how I can compile grass from source code
with NVIZ and postgresql ? )
Not specifically for slackware, as I don't have it, but generally--
Get the source code from:
http://grass.ibiblio.org/download.html
as 5.0.2 has the bug, you might want 5.0.3rc3, from here:
http://mpa.itc.it/markus/grass50/
then follow the instructions in the INSTALL file.
generally, you need to satisfy & install any build requirements (see
REQUIREMENTS.html), which is often the most confusing part as it is
slightly different for everybody.
The run 'configure' with the options you need, for example:
./configure \
  --with-tcltk-includes=/usr/include/tcl8.4 \
  --with-postgres-includes=/usr/include/postgresql \
  --with-motif --with-motif-includes=/usr/X11R6/include \
  --with-glw
(change or omit directory names as needed, see './configure --help')
If that is sucessful, run "make" followed by "make install"
That's it!
Hamish
hello
I am afraid I am not clear on:
--with-motif-includes=/usr/X11R6/include \ # there is not such a directory.
necessary include files may be in /usr/X11R6/GL directory ?
Are motif files necessary ? What are their function ?
--with-glw: this usage is ok. no need to define any include or library directories ?
I could not see REQUIREMENTS.html file in the web page.
I will appreciate if you explains
Ahmet Temiz
General Directory of Disaster Affairs
Ankara TURKEY
______________________________________
Inflex - installed on mailserver for domain @deprem.gov.tr
Queries to: postmaster@deprem.gov.tr
The views and opinions expressed in this e-mail message are the sender's own
and do not necessarily represent the views and the opinions of Earthquake Research Dept.
of General Directorate of Disaster Affairs.
Bu e-postadaki fikir ve gorusler gonderenin sahsina ait olup, yasal olarak T.C.
B.I.B. Afet Isleri Gn.Mud. Deprem Arastirma Dairesi'ni baglayici nitelikte degildir.
NVIZ doesn't require either Motif or GLw. Motif is only required by
xganim and r3.showdspf.openGL; GLw is only required by
r3.showdspf.openGL. Unless you need these programs, I suggest using:
  --without-glw --without-opengl
NVIZ does require both OpenGL and Tcl/Tk. Both of these are normally
found without needing any --with-*-includes= or --with-*-libs=
switches.
It is in the top-level directory of the GRASS source tree.
